Question about Maytag PYE2300AY Electric Dryer
Maytag dryer starts to heat then it stops #pye3200ayw
It feels like it starts to heat. later on it stops, it doesnt get real hot to start with
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    Is this a fairly new one or 15 years old?
    TERRI RODDEN May 11, 2010
    Gas or electric?
  • 101 Answers
There are a couple of things that could be causing this problem for you. First off check and make sure that you have good air flow coming from the vent outside the house. If it feels weak then that is probably your problem. If there isn't enough air getting out the thermostat will shut off the heating element for safety reasons. If the air flow feels good then the problem is probably with your thermal fuse. That is a nice cheap part running around 15 dollars at your local appliance repair shop. The thermal fuse is located on the heating element housing and has two small wires coming off of it. Make sure you unplug the dryer before working on it though. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Posted on Jan 22, 2009
I would like to find out if my Maytag Neptune dryer has heat coils or just a Flame sensor
Go to YouTube and type in - Maytag Dryer heat coils and see if it comes up. Also type in Maytag Neptune Flame sensor on the next search.
Oct 05, 2015 | Maytag Dryers
Maytag dryer stops running after 10-15 seconds.
Check the exhaust vent in the dryer and the one going outside, sounds like it's plugged. If it's plugged the dryer will get hot real quick and shut off so it doesn't catch fire...
Dec 11, 2014 | Maytag Dryers
Maytag dryer model number PYE3200AYW stopped working and no light comes on when door is open
check the door switch:
Oct 30, 2010 | Maytag PYE2300AY Electric Dryer
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Oct 06, 2010 | Dryers
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
My PYE3200AYW runs but will not heat. Changing
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer2.gif. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
145 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
