Question about Car Audio & Video
1996 BMW 325i convert speaker problem - Need help
Hello, I bought this older car and it had blown speakers. I went to circuit city and bought a new radio and speakers to bring it up to date - and be able to listen to my ipod. The bad news is - I spent over 550.00 and it really does not sound that good. It is missing a lot in the sound and seems to be all midrange? I bought their top of the line pioneer radio and polk speakers. He was explaining that the door speakers will not work and have to be disconnected and because the speakers have to be such a small size there is only so much sound they can put out and they will struggle. What I am listening to because there are no side ones anymore are the front floor speakers and the back ones and without a woofer and amp in the truck - which is not something I want to do - he said this is the best it can sound. Do you know anything about this??? I really appreciate your time.
  • 50 Answers
Another bmw i used to work as a intaller in mansfield ohio, i got a call one from a customer that had a 318i and noone would touch it including circuit city!! mosty they dont know what they are talkign about. what i did was hard wire all the speakers to the deck and it sounded Awsome with a sub it will sound even better im not sure how yours is hooked up but i do know polk audio is pretty goodstuff especiallt thier db line in regular speaker and momo subs. my suggestion is to hardwire the speakers.
Posted on Feb 25, 2009
Bmw 330i 2007 convertible , fit music media by bmw .after few days speakers made some load noises and radio went off completely .what could be the problem ?
take it back to to the service center that fitted it and have it replaced or repaired
it points to something they have done or a faulty unit
Dec 04, 2015 | 2007 BMW 330i Convertible
325i locks
sounds like the key may be worn out..check the appearance of it if it is worn a little smooth that could cause the problem you're describing.
Apr 28, 2013 | 2005 BMW 325i Automatic
Battery went dead in my bmw its ok now, radio not workin need code for 1998 R reg bmw E42 318i. can u help
These older BMW radios require further special advice in order to see if a code is available.
Try asking here and mention this forum CLICK HERE
Apr 02, 2011 | Car Audio & Video
Battery died recharged cannot get radio working asking for a code. 1995 325i vert bmw
You will require specialist advice for these older BMW radios as many of them use a different code system to the more modern BMWs
Try here for free advice etc.
CLICK HERE
Jan 04, 2011 | Car Audio & Video
Best Buy installed new stereo in my 1996 Z3 - Now my stereo stops playing when I put the drivers side window down. My car recently started blowing a fuse. Help...it's been almost 4 years since I had the...
:o( you're going to have to pull the radio out to see what they did. They probably added a wire to an inappropriate circuit to power the new radio or amp. I will paste your factory wiring colors below. If you now have an extra wire, that is the likely culprit. Trace it to see where they hooked it in. If it isn't going to the the fuse box and using an extra slot, make it so by connecting it to the cold side of the fuse and put an approprite size fuse in. To determine the fuse size to use, you can compare the wire gage to other cold side wires and use a fuse the same size as you see being used for similar gage wires. Let me know if you have more questions.
1996 BMW Z3 Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Stereo Amplifier Location: Passenger Kick Panel
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow/Red
Left Front Speaker Negative Wire (-): Yellow/Brown
Right Front Speaker Positive Wire (+): Brown/Black
Right Front Speaker Negative Wire (-): Blue/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Black
Left Rear Speaker Negative Wire (-): Yellow/Brown
Right Rear Speaker Positive Wire (+): Blue/Violet
Right Rear Speaker Negative Wire (-): Blue/Brown
Oct 26, 2010 | 1996 BMW Z3 Roadster
2004 BMW 325I RADIO CONTROLS WORK BUT NO SOUND ?? ALSO NO VOLUME INDICATER
You need to check the connection to the speakers and the i/c too.
Cheers
Oct 12, 2009 | 2004 BMW 5 Series
BMW 325I
 I think you are talking about the speaker grille.  Which is the cover for to protect the speaker and not actually the speaker. You would have to remove the door panel to see the speaker, unless trhey are aftermarket speakers.  In which case a stereo shop would have these.  If it is a stock speaker.  Then this is part of the door panel . Try a auto dismantler in your area.
Dec 16, 2008 | 2001 BMW 325
Car Audio & Video Logo
149 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
