Question about Whirlpool Calypso GVW9959K Top Load Washer
SL Code on Whirlpool GVW9959K Washer
Washer runs through Normal Cycle but ends on an SL code
I replaced the pump.
Posted on Dec 29, 2008
Code SL or 5L?
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
Oct 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I keep getting a code "SL" on the display. Before this happens,the washer will stop counting back at 26,and seemingly try to go through the same process a few times. What is the problem and how much might...
Error code "SL" is displayed if suds are detected but the machine is unable to clean it out after three tries with a mini-cycle. This may indicate a bad pump, an extra heavy load, or inappropriate detergent is used.
Press STOP/CANCEL button to clear the display. Do not overload the machine and use a high efficiency (HE) detergent. Use 1/2, or even lower, of the normal amount if regular detergent is used.
The drain pump assembly price ranges between $110 and $130 exclusive of service fee if you ask a technician to replace it for you. Please advise me if the error code still appear on the display for the drain pump troubleshooting and replacement procedure.
Jan 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops and give an SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure and will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool
I would say to worry about it , if its flooding your house , need to open washer front panel ,start a new wash cycle and take a look to see where the water is leaking from , sounds like a broken hose under the tub that connects to the DRAIN MOTOR PUMP , AND BETTER have it fix right away cause if its getting to the main motor it could damage it , hope it helps AJ
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Keep getting SL error code
Sep 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
