I can't get out of a loop: "Start Windows normally", flash new screen, return to 1st screen
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, may I offer an alternate possibility, hardware...
Pls try:
  • remove the memories, clean the little gold pins with a hard rubber eraser;
  • if more than one memory stick is present, test/try one at a time.
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
  • 679 Answers
The first thing you need to do is start in safe mode, by toggling the F8 key before the computer starts up. Once in safemode you can do a system restore Start, Program, accessorys, system tools, system restore. Go back to a day closest to today where the computer was running perfect. If yesterday everything worked, go there. select the day and follow the prompts, wait fou it to re-boot and you should be ok. Worse case scenario we need to clear the cmos "where the battery sits", but try it this way first. If on the way to safe mode it offers you the choice of going into restore then take it from that prompt, good luck,Gym
  • 2,427 Answers
This happens cause eighter the Hard drive or the windows instillation has crashed, normally you must format and reinstall to fix this issue..
You should first try
1.) when it boots and ask you to start normally select safe mode
2.) If it boots into safe mode, shutdown and restart
3.) Hope it works
If that fails you mist first insert the original windows cd that came with your computer.
1.) enter setup (it usually displays some keys on the screen when you turn the computer on, normally its del or F2 to enter setup.
2.) sent the first boot device to cd rom (its located in boot options or advanced)
3.) Save and exit setup (F10 then y then enter)
4.) It will display Press any key to boot from cd rom (press any key)
5.) follow the onmscreen instructions to eighter repair the windows or install a fresh one..
If the instillation fails to detect a harddrive or cant format it,, Its the harddrive thats crashed and you will need ti replace it.
  • 6,487 Answers
Try to boot to Last known good configuration or safe mode so we can check what is really causing the problem,,,,
  • 837 Answers
Shut down
Restart
while restarting press F8 key
select Disable automatic restart on system failure
Let us know what error(s) you get then
  • Jay Glendenning
    Jay Glendenning Dec 29, 2008
    rholtz2,
    Have you tried any of our suggestions?
    There are errors but until we know .. We can't help any further.
    crayz
    President:
  • 948 Answers
Try to get into safe mode by pressing F8 immediately after the post screen. What computer and what OS are you using?
  • 19,396 Answers
That means that system installation is damaged, you need to use a windows setup disk to reinstall the system.
    President:
  • 1,314 Answers
When it comes to the start windows normally screen, use the arrow keys and select the disable automatic reboot on error option. Then post back what it says.
    Master:
  • 763 Answers
This is a common problem of windows that has infected with virus or some spyware. i experienced this myself. format your computer with a new windows to solve your problem.
thank you for using fixya
CHARCOIS
How can i get a free download of windows 8.
there is no such thing as a free download of a microsoft product
you may get a disc for win 8 but to make it work you will have to buy the licence to register it and that is as costly as buying the disc to start with
the only free operating systems are LINUX--ubantu and it is far better than microsoft when you get the hang of uing it
Jan 10, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
What is the difference between windows 7 editions: starter, home basics, home premium,ultimate, professional,interprice?what is the difference between service pack 1 & 2???pc
Since October 31, 2013, Windows 7 is no longer available in retail (except for the Professional edition preinstalled):[6]
Windows 7 Starter Windows 7 Starter is the edition of Windows 7 that contains the fewest features. It is only available in a 32-bit version and does not include the Windows Aero theme. The desktop wallpaper and visual styles (Windows 7 Basic) are not user-changeable. Microsoft originally intended to restrict users of this edition to running three simultaneous applications but this limitation was dropped.[7]This edition was available pre-installed on computers, especially netbooks, through system integrators or computer manufacturers using OEM licenses.[1][8][9] Windows 7 Home Basic Windows 7 Home Basic was available in "emerging markets", in 141 different countries.[10] Some Windows Aero options are excluded along with several new features.[1] Home Basic, along with other editions sold in emerging markets, include geographical activation restriction, which requires users to activate Windows within a certain region or country.[11] Windows 7 Home Premium This edition contains features aimed at the home market segment, such as Windows Media Center, Windows Aero and multi-touch support.[12] Windows 7 Professional This edition is targeted towards enthusiasts and small-business users.[1] It includes all the features of Windows 7 Home Premium, and adds the ability to participate in a Windows Server domain.[1] Additional features include support for up to 192 GB of Random-access memory (increased from 16 GB),[13] operating as a Remote Desktop server, location aware printing, backup to a network location, Encrypting File System, Presentation Mode, Software Restriction Policies (but not the extra management features of AppLocker) and Windows XP Mode.[1] Windows 7 Enterprise This edition targeted the enterprise segment of the market and was sold through volume licensing to companies which have a Software Assurance contract with Microsoft.[1] Additional features include support for Multilingual User Interface(MUI) packages, BitLocker Drive Encryption, and UNIX application support.[1] Not available through retail or OEMchannels, this edition is distributed through Microsoft Software Assurance (SA).[1] As a result it includes several SA-only benefits, including a license allowing the operating of diskless nodes (diskless PCs) and activation via VLK.[14] Windows 7 Ultimate Windows 7 Ultimate contains the same features as Windows 7 Enterprise, but unlike the Enterprise edition, it was available to home users on an individual license basis.[1] Windows 7 Home Premium and Windows 7 Professional users are able to upgrade to Windows 7 Ultimate for a fee using Windows Anytime Upgrade if they wish to do so.[1] Unlike Windows Vista Ultimate, the Windows 7 Ultimate edition does not include the Windows Ultimate Extras feature or any exclusive features as Microsoft had stated.[1] All editions will receive Mainstream Support (new features and bug fixes) until January 2015 and Extended Support (security updates) until January 2020.[15]
Dec 08, 2014 | Computers & Internet
How can i download falsh player on to 2011 imac desk top threw Linux ubentu browser ?
Ok, there are a number of issues with you spelling so I am going to assume you meant the Ubuntu OS. If that is the case the Flash Player install is done by the following:
If you are using the more modern versions of Ubuntu, simply install the Adobe Flash application from Ubuntu Software Centre.
If you are using a version that does not support the Software Centre, try:
Go to the Adobe website.
  • Click on "Download the Latest Player," and choose ".deb for Ubuntu" from the drop down list.
  • Choose "Save File" from the pop up window.
  • Open a terminal window.
    The terminal window will be found under Applications -> Utilities.
  • Change to the directory where your downloaded file was saved.
    cd Download
  • Install the libcurl3 library: sudo apt-get install libcurl3
  • Install the Flash Player: sudo dpkg --install install_flash_player_<version>_linux.deb
    Replace <version> with the latest version number.
  • Restart Firefox.
  • Check that Flash Player was installed.
  • Jul 08, 2014 | Computers & Internet
    How do I delete amazon toolbar from my laptop
    Hello there,
    To remove the "Amazon toolbar" from your Windows 7 or Vista, please follow these instructions:
    1. Click on the Start button, then click Control Panel
    2. Click Uninstall a program or Programs and Features
    3. In the list of applications select Amazon Browser Bar or Amazon 1Button App and click "uninstall"
    If you're running on Windows 8 then follow these steps:
    1. Right-click in the lower-left corner of your screen, then click Control Panel.
    2. Click Uninstall a program or Programs and Features.
    3. In the list of applications select Amazon 1Button App and cilck "uninstall"
    This is public information that i found, maybe it will help: https://www.youtube.com/user/distromatic/playlists
    This will remove Amazon toolbar from your system.
    Hope this helps :)
    Jun 07, 2014 | Computers & Internet
    Screeen is upside down
    If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
    For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
    I hope this helps.
    Jun 01, 2014 | Computers & Internet
    Http go acer com id 17883
    I remember my password I wrote it down and even then it won't let me in. If I cannot get into this computer I will return it.
    Mar 13, 2014 | Computers & Internet
    Don't start up
    check that all removable media is removed from computer, flash drives etc,if this message still appears the reinstall your os, there are several reasons for this error. You may have to replace your hard drive if that is the issue- you would know because after reinstall (if it makes it thru it) it will only crash again, this is much too big of a subject to sum it all up here and now, good luck... more questions just ask
    Mar 30, 2013 | Computers & Internet
    Www.hp.com/go/techcenter/startup
    My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
    Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
    System temperature (90D)
    Apr 08, 2012 | Computers & Internet
    How do i reset my computer to an earlier date?
    Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
    Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
    Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
    I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
    Jul 27, 2011 | Computers & Internet
    Computers & Internet Logo
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
