Question about Toshiba 36AFX61 36" TV
Toshiba 36afx61 tv
I have the dreaded horiz line across my screen, sound is fine and you can see the picture is scanning, in the past a few whacks on the back and the picture would come back. probubly a cold solder? where can i get a schematic for this or any suggestions.
  • robert oneill Apr 27, 2007
    this seems to be a common problem with toshiba tv's does anybody knoww exactly what my problem is
    could the vert output ic be bad because this always happened when playing high speed video games
    President:
  • 3,130 Answers
You have a cold solder connection on the vertical output IC or in the sweep power supply that feeds the voltages to the vertical output IC. You can download a service manual from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=36AFX61 Good Luck
Posted on Apr 27, 2007
Projection TV no picture flashing horiz arcs across top of screen sound okay
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba Televison & Video
TV had moisture get in. TV status- Turns on fine, sound is fine, but no picture, just a white line horizontal across middle of screen
Field scan drive has gone, This requires your local repair shop.
Give them a call first and describe the problem.
Moisture causes problems with the circuit board long after it has dried out.
There may be other problems only evident when the picture is restored.
Best weigh up the cost of a repair V a new TV( with 5 year guarantee - advised)
Feb 12, 2011 | Toshiba 20AF41 20" TV
I have a Sanyo DS13590 abt 6yrs old. I have sound But no Picture just a line across screen.
you need to replace the voltage regulator and the horiz out transistor on the main board
Oct 01, 2009 | Sanyo DS31520 31" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Vertical output problem
you probably just need to resolder the vertical output IC. It will be mounted on a heat sinc. probably 7-10 pins. Part number may start with "LA" like LA7845 or similar, there are others though. You will probably see the rings around the solder joints on the bottom of the board. Good Luck
May 17, 2007 | Toshiba 36AFX61 36" TV
Screen white tinted, horiz lines, then shuts off
Not acutally a solution. We are having this EXACT same problem; it started this week. Let us know what you are having done. I've called Toshiba and service reps but they are all quoting a price which is almost half the value of the tv. Have you been able to fix it? We are pretty upset since the 2year warranty recently expired. Obviously, it seems that others are having this problem as well. Email us: briamanda@comcast.net
Dec 21, 2006 | Toshiba 32AF43 32" TV
Toshiba 36AFX61 36" TV Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
