Question about Cross Furnace Draft Inducer Blower 115 Volts Fasco # A064
Tempstar draft inducer motor noise
We installed a 90% efficient Tempstar furnace in 2004. The draft inducer motor (our installer calls it a venter motor) started making a "growling" noise when it started. This noise carried on until the main blower kicked in and then it stopped. We have had the "smart valve" changed once and this is the 4th inducer motor. I believe the installer is as stumped as I am. What could be the problem? The last motor only lasted one day before it started making noise.
  • 1 more comment
  • Anonymous Jan 08, 2009
    We had our inducer replaced as well, and it was "growling" within a year. It turned out to be the bearings in the motor; they had gone bad. It was a Fasco motor. It required that we purchase a new one.
  • Anonymous Feb 03, 2009
    I have the same problem. Bad bearing. Seems to be common in these motors.
    You have to replace the motor.
    Fred
  • Anonymous Mar 20, 2009
    Same inducer motor noise with my furnace. The inducer motor has been replaced last year and new one is now making the same noises.
3 Suggested Answers
SRF518
  • 232 Answers
SOURCE: draft inducer making noise when turned on
check for "stuff" inside the housing
Posted on Oct 16, 2009
  • 288 Answers
SOURCE: heil 75kbtu gas furnace 80% efficiency installed
if it has a pilot, you can follow the pilot tube from the gas valve back to the burner assembly and find it. It may not have one and if this is the case, the air flow switch is supposed to close when the inducer fan comes on . If the flue is clogged, condensation in the bottom of inducer fan(would hear cracking). then after the draft safety switch is closed,the gas vavle will get 24 volts and allow the gas valve to open
Posted on Dec 23, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Tempstar gas furnace fan inducer comes on but furnace will not ingnite?
you have something activating ths pressure switch possible blockage in the intake or exhaust
Sep 09, 2010 | Heating & Cooling
Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Jan 07, 2010 | Heating & Cooling
My tempstar furnace will not light
look for the fot surface ignitor . it has probably failed and will require replacement. it will be located in or about the burners ( in center ) . or to left of center .. do not touch the ignitor when installing ..or bang it on anything . they break easy. mm
Dec 12, 2009 | Jackson 25 in. TempStar HH-ST...
The fan motor went out and the furnace is not even 5 years old.
I have an Amana High Efficiency furnace that I purchased 5 years ago this past October (2009). My furnace started making a horrible noise last night and then stopped working. The repair person, told me my draft inducer motor needed replaced, and showed me where the plastic fan blade inside of the inducer was "chewed up." Of course my first question is, "How can a 5 year old furnace need such a costly repair already?" The only answer I received is that it will cost me close to $500.00 to have the situation remedied (service call, parts, labor). I started looking around on the internet today, and discovered that high efficiency furnace inducer motors are usually encased in plastic and the motor fan blades are made of plastic rather than metal like the lower efficiency models. Turns out that these plastic blades over time can't withstand the high heat generated and in time (they estimate 3-4 years) break. The damage to the blades causes an imbalance in the way they spin, which in turn, generates the resulting problem of a damaged draft inducer motor. Appears this is a design flaw. Yeah! I'll say. I spent $3100.00 for a brand new furnace and 5 years later I'm paying another $500.00 and apparently can look forward to doing the same in 3-5 more years! Maybe this answers in part your question?
Dec 07, 2009 | Goodman Furnace Draft Inducer Blower ...
Goodman: My Power Venter (aka Heat and Draft Inducer) won't start
The power ventor most likely needs to be replaced. But be advised. Goodman normally will not sell parts to anyone but a certified technician. I had to show my masters certificate to buy parts from their outlet. This is a part that has a high rate of failure.
Ray
Dec 01, 2008 | Goodman Heating & Cooling
Cross Furnace Draft Inducer Blower  115 Volts Fasco # A064 Logo
2,548 people viewed this question
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
