Question about Dell Inspiron 6400 Notebook
Problems with explorer.exe (windows xp)
I have a problem with my machine when i want to turn it off, it says that EXPLORER.EXE no responde and the machine doesn´t turn off, it happens when i got connected to internet, i do not know what to do...please help
  • LUIS JUSTINIANO
    LUIS JUSTINIANO Apr 28, 2007
    Thanks baab, y already have an anti spyware and it didnt help...
    I am going to try reinstalling my windows XP and see what happen, what do you think ??
  • LUIS JUSTINIANO
    Thanks baab, but i already scanned my PC witch two anti spywares and it didnt help..
    I am going to try reinstalling windows xp and see what happen...what do you think ???
    Novelist:
    Scholar:
  • 104 Answers
You might have a case of spyware on your system! But that's a maybe! Its telling you "Explorer.exe not responding" message probably cause explorer.exe is busy! The reason i think its spyware is cause the problem started when you first connected to internet(spyware breeding ground) Explorer.exe is the main Windows Shell (Start menu, desktop and so forth). When you log in to your computer, it starts and runs until either you log off or shutdown! Try getting an anti-spyware solutions if you don't have one already! try AVG Anti-spyware, its pretty good! Install it, update it and do a scan. If that doesn't help then I might need more information. 1.)Go to majorgeeks.com 2.)download this utility - HijackThis http://www.majorgeeks.com/download.php?det=3155 3.)double click on it(it extracts) 4.)go to c:\program files\hijackthis\ Doubleclick on the Hijackthis.exe 5.)Click ok at the warning 6.)Click on Do A system Scan and Save a log file 7.)When the log file pops up in notepad, Select All, copy, and Post it back to this Post! 8.)Close the hijackthis! Warning! Be careful with the hijackthis program! don't do anything else with it unless of course you know what you are doing! Good Luck! Regards, Babb Good Luck, Babb
Posted on Apr 27, 2007
  • Armando  Babb
    Armando Babb Apr 27, 2007
    At majorgeeks.com you might need to do a search for hijackthis
  • Armando  Babb
    Armando Babb Apr 28, 2007
    Well, a re-install most of the time always works, just remember to back-up your data!
    However not only spyware itself can cause the explorer.exe to hang! Some other good applications might be the culprit. Cause explorer is having difficulty closing them down!
    You can set this registry tweak to see if that helps:
    HKEY_USERS\.DEFAULT\Control Panel\Desktop
    AutoEndTasks=1
    or download a script here:http://www.aumha.org/downloads/autoend.z...
    exract then double click on the file autoend.reg
    If that doesn't works then i guess you can go ahead with the re-install.
    Regards,
    Armando
Explorer.exe
Try to boot in safe mode. If safe mode loads explorer.exe, then create a new user as administrator in the safe mode.
Mar 16, 2012 | Microsoft Windows XP Professional With...
Start menu and task bar is not responding for a mean while after i turn on my computer.
Please follow the given steps to relaunch the Start Menu and Taskbar:
1. Press Ctrl + Alt + Del or Ctrl + Shift + Esc to bring the Task Manager.
2. Go to Processes TAB
3. Find explorer.exe and select it
4. Click End Process (Button at Bottom Right Corner)
5. Click File Menu and Select New Task (File-->New Task(Run))
6. type in explorer and press ok
May 18, 2011 | Microsoft Windows XP Professional
The instruction at "0x71ab664d" referenced memory at "0x71ab664d"
I think this article will help you solve the problem: http://www.fileinspect.com/fileinfo/explorer-exe/. It specifically deals with explorer.exe errors.
Jul 05, 2010 | Microsoft Windows XP Professional
Explorer.exe is failing.
Hi.
I had this problem before with my Windows Xp professional . in fact i could solve the problem only by making a new formatting to my computer . and i installed my Xp pro again .
If your Vista is not the original one , then you have to disable the Automatic updates to prevent this to happen again .
rate if useful please !
Jan 16, 2010 | Computers & Internet
Win XP Pro SP3 Explorer.exe problems
Hi there, Start your computer in SAFE Mode, by pressing the F8 repeatedly, then scan you pPC for any viruss infections, scan for spyware too...
Restart your PC normally, see if it worked, otherwise do a repair on your machine, using the origanal windows disk, be carfull not to format it, as you will lose your data,
Let me know if you need any further help regarding this problem
Cheers,
Please be so kind just to rate this solution at the end...
Thanks Tehmor
Jun 04, 2009 | Microsoft Windows XP Professional With...
Explorer.exe Application error in Windows XP Professional SP2
hello ! what you should do put another HD then install XP the reason for this messages could be due to registry .
if you are getting the same messeges get another cd of XP
GOOD DAY
May 27, 2009 | Microsoft Windows XP Professional
My computer Desktop is not running.
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
Mar 26, 2009 | Microsoft Windows XP Professional SP2
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
Nov 27, 2008 | Microsoft Windows XP Professional
Explorer.exe
Insert Windows XP cd on drive, and use upgrade option.
Dec 13, 2007 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
293 people viewed this question
Clive
Clive
Alun Cox
