Question about Monster Cable (109611)
Getting ready to replace my 2WIRE router
I am about to replace the 2WIRE router. Why? Wireless is not wokring properly. My new macbook does not connect to it that good. It drops out. I experience this problem most of the time. Is it possible that other routers will work? I got this plastic internal antenna thing for $19.99 cheap eh?
I am soon going out to buy a Belkin router probably N or mimo. I noticed it is the router because my friend's Powerbook G4 as the same problem too. (The 2WIRE probably hates macs)
It has been a YEAR already and 6 months with the thing. Even sometimes it happens to PCs (I have a 2 Toshibas)
I hope this is enough information for all of you reading this. Please reply if buying a new router helps. Thanks. JC
    Problem Solver:
  • 13 Answers
The solution may be as simple as placement of the router/antenna, or it may be a configuration mismatch between the MacBook and the router. 2Wire is a fairly common router used by some ISPs, the router might be configured to use IPv4 and the Mac might be configured to use IPv6 (different address schema), or the channeling might be set different (encryption setting mismatch). Since the problem seems to occur mostly with the newer computers, I would lean more toward a configuration problem, but recommend checking the antenna first (this would automatically transfer to a new router), then check the settings. Depending on the environment of the router, the time may have come to get a new one (I have seen some last many years and some last only months).
Check that the following are set the same on the router and the Mac's:
  • IP Addressing schema
  • Encryption settings
  • Channel and frequency settings
If you are going to relace your hardware, I recommend a router with MIMO technology using the 802.11g standard. As far as the 802.11n standard, keep in mind that it has not been approved and published in its final form yet, this could mean that any technology using this "pre-standard" may become obsolete and unusable overnight.
Posted on Jan 09, 2009
2 Suggested Answers
Atomik81
  • 46 Answers
SOURCE: I am about to replace
The new router should help because of the extended range that they have. You may also have an issue with your computers wireless device. I wiould recomend seeing if you can connect to someone elses wireless device before making the purchase of a new router. Some computers have a weak wireless adapter built in.
Posted on Dec 29, 2008
My at&t 2wire router dsl and internet light flash red often every 1 to 5 min
Hello, there could be a few things causing this problem. The router could be defective, or just died or you may not be getting enough power over your line from ATT. I would call ATT and ask them to test your line and see if everything is working properly. If it is, then you need to replace your modem/router. Any Dsl Modem and Wireless router will work.
Thanks for using FixYa!
Jul 12, 2011 | 2wire (1000-400108-001) Router
I have a wireless connection problem between my macbook and my 2wire modem. It keeps dropping the connection.
If you can check the 2wire website for your router model and see of there is a firmware update. Also if you are using a wpa or wpa2 security try lowering it down to wep. Wep is less secure but it also provides more compatibility with many devices.
Here is a link to the support page for there routers:
http://support.2wire.com/index.php?page=download&cat=1
Mar 06, 2011 | Computers & Internet
Will a netopia 3-d reach wireless adapter work with my 2wire 3800hgv-b router from u-verse?
if you are wanting to run stricktly wireless then no if your router is not wireless ready. If it only has wired connections and not wireless capable you will have to be wired into it using a cable.
Oct 17, 2009 | 2wire HomePortal® 1800HW Router...
My dsl light is on green but my power light is on red. After a while no lights are on. My router is a 2wire that's about a year old
These 2Wire devices are known to have their wall-wart weaken over time. Although you can measure the proper voltage coming from the wall-wart, when you load it with the DSL modem, the actual voltage drops giving you the red power light. The green DSL light may or may not be accurate while the DSL modem is not getting the power it needs. Look online or go to a store like Radio Shack for a replacement wall wart.
Aug 26, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I have a 2wire router, if I purchase a couple new laptop computers which are wireless ready, do I need to purchase wireless adaptors for networking?
No, not at all.
I can't even think of a newer laptop model that comes without wireless capability anymore.
Which 2wire router you have, determines the speed of your wireless network.Make sure when you buy a laptop, that it's wireless capabilities match those of the router. The standard today is 802.11g, backwards compatible with 802.11b. 802.11n is a new standard (backwards compatible to 802.11b/g), and both router and computer have to support this standard in order to use it.
Aug 15, 2009 | 2wire (1000-400108-001) Router
Can I use old 2wire router to connect PC to new wireless router?
Hi, You can not use a router to connect a computer to another wireless router. You need to purchase a wireless adapter if you want to connect a computer wirelessly to the network. There seems no other way of doing this.
Let me know if you need any further help regarding this.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Where do I locate wireless router settings SSID?I am trying to set up a wireless HP Photosmart C6380 All-In-One to connect to my new Macbook?
Go to your Router's "System Summary" and go to Home Network tab. Then click wireless settings. SSID = Network Name.
Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Macbook airport tooooo slow
When your MacBook Air is showing some performance issues, it can be caused by either hardware or system problems. If you don't want to pay for hardware upgrade, then try cleaning the system to improve the Macbook speed. Learn more here: http://www.speedupmacbook.com/speed-up-macbook-air.html
Feb 24, 2009 | 2wire HomePortal® 1800HW Router...
I am about to replace the 2WIRE router. Why? Wireless is not wokring properly. My new macbook does not connect to it that good. It drops out. I experience this problem most of the time. Is it possible that...
Dec 29, 2008 | Monster Cable (109611)
Getting ready to replace 2WIRE router
MAKE SURE THAT THE ROUTER IS NOT INSTALLED ON A CARPETED FLOOR: EVEN THOUGH YOU CHANGE ROUTER AND IT IS STILL WITHIN AN AREA THAT IT may encounter interference FOR THE WIRELESS SIGNALS
ANY ROUTER WOULD DO.
Monster Cable (109611) Logo
125 people viewed this question
Top Monster Cable Computers & Internet Experts
David Payne
David Payne
Are you a Monster Cable Computer and Internet Expert? Answer questions, earn points and help others
