Question about Maytag MMV4205 Microwave Oven
Complete lost of power - where's the fuse?
2 year old Maytag 4205 over the range microwave It was working fine, until it wasn't. No power, no display. I have confirmed power to the socket. I'm hoping that there is a fuse I can access if I drop the microwave, or perhaps some reset button???, but I thought I'd ask for info/advice before I pull the heavy machine out. Thanks for your help
  • Anonymous Dec 07, 2007
    I have the same problem. Checked the fuse on the topside of the unit on the mini circut board and that was NOT the problem. Still in work...
  • Maytag Master
  • 9,156 Answers
You'll want to unlplug it first. On an over the range model, you probably want to remove the grille, then you'll see the screw holding the control panel in place. Then the panel will slide up and out or swing out. Don't break the mounting tabs or it will be loose. The fuse should be behind the control panel on the floor of the chassis, or among the door switches. If the fuse is good, there will be one thermal cutout or thermostat mounted on or near the magnetron and one on or near the top of the chassis. If it's the latter, the oven will probably have to come out of the wall. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find exploded views and parts lists for model MMV4025AAW at http://www3.sears.com
Posted on Apr 27, 2007
SOURCE:
My Maytag over the range microwave is only 3 years old. No power. Changed the fuse - made sure the outlet worked on other appliances.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Maytag MMV5207BAW Microwave Oven
Maytag mmv 4205 microwave, plugged in but no power
Check the house circuit breaker to see if it has tripped or the internal line fuse and see if that is blown.
Dec 06, 2010 | Maytag MMV4205 Microwave Oven
Maytag Microwave apprears to work but does not cook
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Maytag MMV4205AA - Just went dead
It is a thermal fuse Ijust don't know where it is located
Apr 15, 2008 | Maytag MMV4205 Microwave Oven
Maytag above the stove microwave not working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Apr 14, 2008 | Maytag MMV5165 Microwave Oven
MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Aug 04, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV4205  Microwave Oven Logo
125 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
