Question about SanDisk Sansa e260 MP3 Player
Help how do u delete songs off of e250r's
    Scholar:
  • 47 Answers
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Posted on Apr 27, 2007
SOURCE:
E250r shows as e200 when I plug it in to renew.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Other solutions are in the above link, make sure u follow directions for 2xxR and not the 2xx..............
How to get rid of the "synchronize to continue music subscription" message if it just appears out of nowhere on your player- this fixed mine when it gave me that message:
delete the STORE.HDS file in the system/wmdrmpd directory of your sansa (optional)
import your protected songs into WMP, and resync your protected music (with WMP) in MTP mode
play a protected song and let it rebuild the store.hds file (you will experience severe lag for about 15 seconds as it rebuilds) and the music should play.
Sep 25, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sansa e250 mp3 player.....HELP please !
Try going to "My Computer" find your device on the removable devices, right click and format.
Aug 06, 2008 | SanDisk Sansa e250 MP3 Player
Can't delete music or load music on my sansa e250r 2.0
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
May 15, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Weird file in my Sansa e250r.
go to www.download.com and search for a program called Unlocker 1.8.5 it's free... after installation, right click the file to unlock the file and it should be fixed to delete... I was on here cuase my unit froze...
Jul 31, 2007 | SanDisk Sansa e250 MP3 Player
How do i free up memory?
Delete other songs and files.
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Finding the music to delete
Use Media Monkey instead, or change Windows Media Player's configuration, so that it sees more songs.
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
I can not get the song off that came with the mp3 player. help!!!
It might be a glitch and I had my Sandisc Sansa e250R mp3 player for a very short time but I think if you delete the Rhapsody Channels with the player instead of the computer it might work. Hope it works
Jan 03, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
165 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
