Question about Watches
CANNOT FIGURE OUT HOW TO SET WATCH?
HI BOUGHT MY HUSBAND A RIP CURL WATCH CALLED CONGO MID PU MODEL NUMBER A2155-SIL. IT DID NOT COME WITH ANY INSTRUCTION MANUAL AND IS NOT WORKING ON ITS OWN, SO WE ARE NOT SURE IF THE PRODUCT IS NOT WORKING OR IF THERE IS SOME TRICK TO SET IT AND GET IT TO WORK. WE TRIED THE OBVIOUS OF WINDING IT BUT, THERE WAS NO LUCK? ANY HELP IS GREATLY APPRECIATED!!! THANKS! I AM THINKING ITS A BATTERY IF THERE ISNT A TRICK, OF COURSE IT ADVERTISES 5 YEAR WARRANTY HOWEVER THERE IS NO PAPERWORK??? THANKS
SOURCE: How to set time on Diesel DZ 7071 Watch
Finally i found it...
I had the same problem and when i was clicking (holding) the upper left button (A) the only thing that was appearing was the offset and i had the only option to increase or decrease the hours!
The problem IS that, in order to set the time, you must have the T1 (Time 1) enable and NOT the T2 (Time 2).
How to change between T1 and T2, click and hold the upper right button (C).
When you finally are on T1, click and hold the upper left button (A) and you are set to go!
Click the lower left button (B) to scroll through various functions!
I hope this is the best solution for you!!
Enjoy it
Posted on May 01, 2008
SOURCE: setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Posted on Aug 06, 2008
  • 79 Answers
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Posted on May 15, 2009
SOURCE: Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
Posted on Feb 04, 2010
  • 15 Answers
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Posted on Feb 23, 2010
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
Tip
RIP CURL WATCH INSTRUCTIONS.
Follow this link and sort out you RIP CURL watch settings: http://ripcurl.com/?watchcareprocedures
on Apr 01, 2010 | Watches
Light doesnt work
battery could be low, i have had a similar thing happen with a large face rip curl watch, works fine until you press the light button, theres not enough current left to run the face and the light. mine was almost new too, so even if you just got it it could be that!
Jan 17, 2014 | Ripcurl Rip Curl Trestles Oceansearch Tide...
How to Turn the hourly chime off on Rip Curl Trestles Oceansearch watch?
HI try holding buttons longer i think holding bottom left is the standard you may have to hold for a few seconds to see the change.
I hope this was useful
Oct 25, 2011 | Ripcurl Rip Curl Trestles Oceansearch Tide...
Is there an electronic copy of the operators manual for a Rip Curl Shipstern Tidemaster 2 watch ??
Go to http://www.ripcurl.com/index.php?id=683,4215,0,0,1,0 and select "watch warranty and care".
On the right you will find "
Watch Warranty & Technical Information Booklets Download.
Download the instructions.
Dec 18, 2010 | Ripcurl Rip Curl Shipstern TideMaster2...
Would like instructions to set RIP CURL 17146 Tide Watch
browse through my tips and you will find link for all RipCurl watch manual downloads.
Sep 30, 2010 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
