Question about Ricoh FAX3800L Plain Paper Laser
Installing a ricoh fax3800l
I just brought a machine as indicated on the subjsect line. I having trouble installing it with out a port. How do I and can I connect it to my home computer.
  • 59 Answers
You must get the optional printer port for this model. It does not come standard with the unit. Last sold in 2002
Posted on Aug 10, 2007
We can receive faxes, but cannot send
Are you using a digital telephone line or analog. Fax machines still run on analog technology and can't handle the speeds of DSL or Cable lines. This could be your issue.
Oct 29, 2009 | Ricoh FAX3800L Plain Paper Laser
How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
Installing windows xp professional
You will have to format the new hard drive. Boot the pc with the windows installation cd and when it asks if you want to format the hard drive select yes.
Jun 03, 2008 | Intel Motherboard
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Error message 3-31H
This is a failure of the polygonal mirror motor. To check, Test point CN14-4 on the FDU board. If it does not go to low within 10sec of the motor being turned on. Motor has failed. Also check test point CN 14-1 that +24v is supplied to the motor.
This is a common problem, it is simple to change. However, the machine must be reset after each test.
Jan 25, 2008 | Ricoh FAX3800L Plain Paper Laser
Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Nov 07, 2007 | Ricoh FAX3800L Plain Paper Laser
Service Call 3-31H is displayed on the screen
The technical manual is stating that the problem is with the left lock lever make sure that the door is shut correctly power down then back on again. If the problem comes back I think it maybe the laser unit then and it will need replacing.
Thanks J
Oct 17, 2007 | Ricoh FAX3800L Plain Paper Laser
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
No confirmation sheet
first i need to know if it receives or copies,if it don't.that code is is heat lamp(fuser) problem.
Sep 13, 2007 | Ricoh FAX3800L Plain Paper Laser
Ricoh FAX3800L Plain Paper Laser Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
