Question about First Alert 24 Hour Timers - 2 For The Price Of 1
Pointer is stuck at 9:00; difficulty setting accurate on/off time
The pointer arrow that says current time is stuck at 9:00 making it difficult to set an accurate time.  Does anyone elso have this problem.  It's a guessing game right now when it will go on or off.
I've lost the user manual, but i would try the following:
1.) this might sound like an obvious point (maybe not), but you can turn the dial clockwise so that the "current time" arrow is on the current time.
2.) i'm not sure, but it's possible that this device functions best when it DOES NOT share a single outlet.
3.) i don't believe this device functions correctly while plugged into an extension cord.
Posted on Jan 05, 2009
Charger charger charges but gets very hot . pointer arrow starts jumpingon screen gets difficult to control pointer sometime without warning? if charger replacement? where to get it . thanks
Search for a replacement charger on amazon with the brand name and model of your device - then buy it and try.
Next time, be specific as to whether your question is for a laptop, tablet, cell phone or something else. Give details of model, make etc. Providing the ratings written on current charger will also help answering your question(s).
May 07, 2015 | Computers & Internet
Is the day of the week in the middle of dau or night or at the beginning it on the GE vacation timer?
Vacation timers turn lights on-and-off at random times.
Timer dial rotates clockwise. Notice small arrows on timer dial located below each day letter.
Each day starts at the letter.
When the time-now pointer is at W, then wednesday starts.
For example W is wednesday. And th is thursday. The hours that show between W and th are wednesday hours.
Open following image. The time now pointer is pointed at 4:00pm Wednesday.
The blue letters with white background are AM, and white letters with blue background are PM.
To set current time, rotate dial clockwise until current time lines up with time-now pointer.
Time-now pointer is stationary.
Open following link to see how to set timers by experimenting with features.
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | GE 50462 7Day Random Vacation Timer
Can I move the stationary pointer clockwise and counterclockwise or will it break the devise
It is not necessary to move stationary pointer:
The stationary pointer points straight down at 6:00, and is used as a mark for setting current time.
Lift and rotate yellow dial until current time lines up with the pointer.
It will not break anything by moving the pointer, but you might forget the current time location.
Open following links to explain how timer works:
Take a moment and vote on answer:
Aug 27, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
I purchased a model t8845pv automatic sprinkler,it was set for wednesday/saturday at 10 pm (pins up on those days,day on correct arrow) but is coming on tuesday/friday at 10 pm
Be sure to set the current time of day. To do this: turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT attempt to move the silver pointer.
You can read the manual at Intermatic's website.
I hope this helps and good luck! Please rate my reply. thank you.
Jun 15, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
The instructions are not very clear on my new UPM ET420C Electronic Outdoor Timer. What I want to do is have the time turn on power everyt morning at 3am, run for 2 hours, and stop at 5am. Could you tell...
Using the right & left arrows, go to CLOCK to set the current time & day.
Press SET
Using arrows, set the day, press SET.
Using arrows, select the hour, press SET.
Select the minute, press SET.
Select the second, press SET.
Using right arrow, press once for program 1.
Press SET.
Select day, press SET.
Select hour, press SET.
Minute, SET.
Repeat this for every day you want this program, five days or seven days,
Programs 1-5 or 1-7.
Gary, good luck, these instructions are difficult.
May 27, 2011 | UPM Programmable Outdoor Timer
I have a HB31R timer and asm having difficulty setting the timer. Please help.
Make sure the on and off indicators are approximately an hour away from the current time you wish to set the timer to. Using your thumb and one of your fingers (ring, index or middle) grasp the edge of the yellow time indicator. Pull the time indicator straight out away from the back of the unit. While the time indicator is pulled out rotate the wheel to the correct time in reference to the time pointer. Release the time indicator and set the on and off indicators to the desired times in reference to the time printed on the time indicator. Manually move the bottom switch to on or off state which the timer should be at the current time. If you do not see the time wheel move after approximately 30 minutes the timer could be defective.
Mar 03, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Oct 12, 2010 | Woods 7 Day Digital Heavy Duty Timer...
How do you change the time on the top of the display screen to the current time, How do you set the day to the current day and year
First, here are the links for your owners manual:
Time displays the current time based on the settings of the active profile.
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
Fundamentals 5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | Magellan Triton 400 Handheld GPS Receiver
Lights stay on
manually turn the dial pass the red pointer. that shoudl shut-off the light.
if not, you have a defective timer.
if it does. follow the instruction set the gree pointer for the time to turn-on and set the red pointer to the time off.
turn the dial one or more revolution till the arrow head in the center align with the time of day in the center windows.
Dec 30, 2008 | Intermatic & Indoor/Outdoor Rain Tight...
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
First Alert 24 Hour Timers - 2 For The Price Of 1 Logo
179 people viewed this question
Top First Alert Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
