Question about Gateway MX3228 Notebook
Lost a Cap, MX3228
When I de-soldered the power jack from the little PCB, capacitor C2 fell off. I am going to pick one up tomorrow, but I have no idea what the capacitance is. I can remeber the size since I can look at the pads on the PCB, but I don't want to put the wrong in. I phoned tech support, but they would want to charge me for their help. If someone knows where I can find a schematicn for my gateway laptop, model # MX3228, I would be most appreciative
  • jozef_de_bee Dec 30, 2008
    Hi Geekman:
    Thanks, but the cap in question is a tiny suface mounted block shaped thing. Although I lost the cap, I did find it, so the cap is no longer missing. There is no writing on the cap that is visible to the naked eye. I have trouble-shot many PCB's in my life, however, never a mother board. In my experience once the block shaped cap is under a certain size there is no polarization. It is close to the power source and probably runs to ground in parallel, but I cannot see the trace or have not seen a schematic so there is no way to be sure. There is two other caps that are right beside them so I would assume the same. One is about three times larger. The lost cap in question is about as thick of two of the lines one my thumb (that you would see in a fingerprint) and three of those same lines long. I don't own calipers, so I can't give an exact measurement. I know that the tolerance on most caps is the sh**'s, by about 50% and ohming the pads it lay on out it reads as an open so, I am fine to leave it. My computer still malfucntions all the same, since the charging is intermittent, a component in the power circuit must be loose, the batter seems to run the computer fine and it will charge after about two days. Thanks for your input, your feed back tells me that I should have explained myself better to begin with. I have never asked for tech help online before.
    I don't have a temperature control dial on my soldering iron, so I will just save up for a new computer in a couple of months.
    Cheers,
    Jozef
  • Gateway Master
  • 32,281 Answers
The capacitor is most likely an electrolytic type, these are a round cyclinder device and they are polarised. From its location near the power jack it is most lkely more than 50uF and more than 20V. The information on the capactance and voltage of the capacitor is printed on the capacitor. If you are going to purchase a new one, make sure you get an exact replacement because if it is bigger in value eg. microfarad and voltage it will be too big to fit on the motherbard and if it is a lesser value, it will fail and not perform as required.
The capacitor is polarised eg + & - legs on the capacitor and these must be soldered in the correct direction on the motherboard, the white stripe on the capacitor marks the negative lead of the capacitor.
If the capacitor fell off during de-soldering of the power jack, you must have applied too much heat for this capacitor to fall off. If the capacitor is not damaged you could solder it back on the motherboard.
You should be using a temoerature controlled soldering iron, applying excessive heat to a motherboard can damage the motherboard as these boards are multilayer boards, there are circuit tracks on top, below and in the middle of the board. make sure you don't put solder across printed circuit tracks, carefully check the motherboard under a magnifying glass.
Posted on Dec 29, 2008
My 46'westinghouse led tv has no picture what can be wrong
If it's not a bad switch, then:
Many problems from later tv's come from bad capacitors. Even though you changed the power supply pcb there are several other capacitors on the other boards. Open it up and look for any caps with the top slightly swolen or leaking. They are inexpensive (as tou may know) to buy and a little bit of trouble to replace. If you can get at the terminal side of the bad cap, then you may be able to desolder it and then use a small drill bit to drill the holes back out, Solder in the new cap(s) and you're set.
p.s. Use capacitors with a higher voltage rating than the ones you take out, but the same uF.
Nov 10, 2017 | Televison & Video
How can I order the PCB schematic and electronic PCB
Check your old board for bad capacitors.
Mine had one bad capacitor. 470uf and 25volts
Hard to replace capacitor because the board is seal.
But can done with some solder knowledge.
Drill hole behind bad cap, 3/4 inch wide. desolder the old and replace
with a same rating cap. Seal hole with tape and reinstall.
Nov 29, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a HP dv7-1240us. My power supply went bad. I purchased a new one now my cpu doesnt charge or even power up. Need some help on how to replace the power socket. I have no idea on what else it could...
Was the new one that you purchased from HP? If so, then did the model numbers of the old one match the new one you bought? If the new one isn't an HP power supply, then that could be the reason why it won't charge your battery. Some of the "after market" power supplies will be enough to run the computer, but they aren't all able to charge the battery. It could also be the DC Jack on the motherboard that has gone bad. If you are not familiar with de-soldering a component from a motherboard, then you may want to think twice before attempting it. You will have to get the exact jack that goes to your motherboard, de-solder the old jack, & solder in the new one. Trust me, de-soldering and removing an old jack isn't always as easy as it sounds. You will have to completely disassemble your laptop to do that too, so be sure to keep track of all the little screws and which screws go where. Check out Madhatter Computers on Facebook, or go to the website: www.madhattercomputers.com.
Jul 20, 2010 | HP Pavilion dv7-1240us Notebook
I have a gateway 3250GZ laptop, the DC in jack
http://forums.whatthetech.com/DC_Jack_Laptop_t105164.html
double check your power cord! i just went thru 3 days of troubleshooting my Gateway M6318. Thought it was my dc jack.... after tearing down my laptop... finding the jack in tact, soldering in tact. testing my power cord... off and on for 3 days.. it was reading 19v.. which is what it should... but as of today began zero reading on tester. Tomorrow I will buy a new power cord to see if this was the correct problem... wish i would have found the above reference site before all the other troubleshooting i had done... tearing down my lap top, pulling, tugging, twisting my power cord to get a good charge.... etc. hope this helps!
Jul 12, 2009 | Gateway MX3228 Notebook
Opening Gateway MX3228
Ok here is instructions on removing to get to the motherboard. It is for a different laptop but removal is exactly the same.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
Feb 06, 2009 | Gateway MX3228 Notebook
No Sound HTS3450
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Apr 20, 2008 | Philips HTS3450 System
Dell monitor not working , green light blinks.
Capacitors look like cylinders mounted vertically on the pcb.
If you look at the printing on the board, there should be a label close to the capacitors such as C201, or XC330.
Usually a C in the label will indicate a capacitor.
They will be wrapped in a plastic jacket. The jacket will have writing on it, and usually a stripe down one side. The stripe indicates the negative lead (each cap will have two leads, negative and positive).
If the cap has a rounded top (domed) instead of a flat top, it is likely bad. You may even see that the component has split at the top, into four pie shaped wedges. This is also an indication of a bad cap. Lastly, the jacket is "heat shrunk" onto the metal cylinder. This usually causes the plastic jacket to overlap the top of the cylinder, which will show up as a donut shaped ring around the top of the cylinder. Some times if the cap is leaking, it will heat up causing the ring to shrink further so that the top of the cap will be completely exposed metal, with no plastic ring framing it. This also indicates a bad cap.
You can get the value from reading the print on the side of the cylinder. The values should be printed down the side of the cap, such as: 1000uF 16V, or 470uF 25V.
This is read as one thousand micro Farads at sixteen Volts, or four hundred seventy micro Farads at twenty five Volts (the u will actually be the Greek letter mu).
You will need a solder ****** to remove the solder from the caps on the solder side of the pcb (under $20), a soldering iron and some solder.
**** the solder after heating it with the iron, use the tip of the iron to carefully unbend the legs of the capacitors if needed.
Install the new caps making sure to observe the polarity. There will either be a mark in the board indicating where the negative lead should go, or a small + showing where the positive lead should go. Solder the leads and cut off the excess.
Make sure you get caps that are not larger physically than the originals or you may not be able to fit them into the same spot. (older capacitors are bigger than the same value newer capacitors).
Hopefully, you will only have three to six caps.
The lucky people will find only one bad cap, unlucky people will find up to ten bad caps, some in the power circuit, some in the inverter circuit, and some on the main board.
Caps on the main board can be very tough to remove. I recommend adding some solder to the legs of the caps you are going to remove, then heat one leg as you push the cap to the side to try and pull that leg out of the solder hole. Then heat the other leg and try to pull the cap completely off the pcb. Once done, you can use the solder ****** to clean the old solder out of the holes. This may be necessary because the main board is multilayer and these layers can act as a heat sink, making the solder harder to melt and harder for your solder ****** to remove. It's slightly easier once the capacitor legs have been removed.
Also note. Some manufacturers will use slightly larger caps, and in order to mount them they will bend the legs and glue the cap to the board on its side.
Mar 27, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
How did u fix it
Mar 17, 2008 | Philips HTS3450 System
Is there really any recourse?
Dec 02, 2007 | Philips HTS3450 System
Home theater system
Sep 22, 2007 | Philips HTS3450 System
Computers & Internet Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
