Question about Acer Aspire 5610-4648 Notebook
Burnt a hole though neer mouse pad!
My son was using it last week, it got really hot and burnt his finger near the mouse pad. I DON'T hear the fan anymore!!! It's still working ok, but i wonder where i can get warranty or new parts?
    Sergeant:
  • 279 Answers
Go to the Acer website and contact them about sending it in for repair. You don't want to be messing around inside a laptop if you don't have to.
Posted on Dec 29, 2008
Cursor Jumping Around
****a piece of Scotch tape over a mouse's laser, might make it work perfectly******
***some optical mouse's need a mouse pad and some work
on any surface.***
i use a lot of computers that have mouse's that i have to
list it slightly and let them ride on a finger when they are
off the mouse pad.
a few weeks ago, my good mouse finally frayed its cord and i
had to start using one of my redundant mouse's that needs a
mouse pad.
i noticed immediately that it could work almost normally if
i lifted it 1/4 inch off the table.
I'm not going to deal with this like that though..
i speculated that it must be because the laser sensor is too
sensitive..( since it works better from farther away....)
i wanted to try to put a piece of scotch tape over it to
act as a diffuser to make it less sensitive, but i was too
busy. lol. so like a month later . i finally tried the tape
idea, and it works perfectly!!!. dam
if you get an optical mouse that goes crazy without a mouse
pad, you should try this
Dec 14, 2013 | SteelSeries Ikari High Performance Laser...
Cq60 frozen mouse pad
Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:
- This is a laptop, yes?
- It has one of those little areas where you can use your finger, instead of a mouse?
- Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.
- If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.
One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one.
Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.
All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.
I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.
Best of luck to you.
Cheers!
-a.
Jun 16, 2012 | Compaq Presario CQ60215DX PC Notebook
Mouse doesn't work. touchpad works fine. lenovo G470
LOL, go into the mouse and touch pad properties and make sure you don't have the mouse disabled or blocked.
Does the point work from the touchpad when you have the usb mouse plugged in? If not you have the mouse pointer disabled. There might be a button at the top of the touch pad in the middle that you press to toggle the mouse pointer. There could also be a set of keystrokes you hit to toggle the mouse. For example I just worked on one last week where you had to Press and Hold the Alt key then hit the F6 key. Function Key F6 had the icon of a finger inside a square which represented the touchpad.
Click Start/Control Panel and look at the mouse and touchpad properties. There may be settings where you can disable one if the other is present.
Apr 08, 2012 | Computers & Internet
Compaq presario CQ40 is overheating within 30 minutes. Although cooling fan is working (fan sound is coming)
Laptop needs cleaning! Only experienced technician should open laptop, clean cooler and change thermal paste. This will solve the problem and save laptop from serious damage.
Jan 13, 2012 | Compaq Presario Notebook
My mouse pad and two click bars do not work? a wireless mouse does work though. why isnt it reading my finger across the pad when i want to use it instead of the wireless mouse?
You may have it disabled. Press and hold the "fn" key then and press the key that has a symbol for the touchpad on it. For my satellite it is the F9 key. Then give it a shot. It should work.
Mar 05, 2011 | Toshiba Satellite L500 Series Notebook
Acer laptop mouse pad gets really hot at times,
thats usually normal but if it shuts down for no reason ,then u need to clean the fans inside
Dec 18, 2009 | Acer Aspire 1640Z Notebook
Laptop Switches off and is really hot to touch
cooling fan not working.on the side of laptop see if the fan ventilation does not have dust covered.
Jun 29, 2009 | Dell Inspiron 5100 Notebook
Microsoft Mouse cursor jumping around
maybe u can use mousepad, with fabric material
May 28, 2009 | Microsoft Windows XP Home Edition
My pointer is down...
might be mouse on off botton is it on turn labtop off back on with out usb mouse on it then buy mircosoft mouses only for best results and easy to use
Mar 13, 2008 | Computers & Internet
Acer Travelmate 4270
ive got the same model. mine gets damn hot too. especially after about 4hrs you can barely type on it or use the mouse pad.
i sent it back as soon as i got it. acer replaced the fan and said it was fine. 4hrs later it was running as hot as before. they probably did nothing but waste my time for 2 weeks. just poor design i spose. poor cooling system poor design. i also noticed the fan air vent is on the right hand side. again poor design, most people are right handed. getting hot air blown on your hand when using an external mouse, during a hot summer day is not pleasant. dont think ill buy an Acer again
Nov 10, 2007 | Acer NSK8458AN Keyboard
Acer Aspire 5610-4648 Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
