Question about Jenn-Air JED8430 Electric Cooktop
I can not separate the glass cooktop from the granite surface.
I wish to replace the solid surface electric cooktop with a gas burner model. The cooktop does not seem to be secured to the granite countertop with any mechanical fasteners yet I can not budge the unit when I push from below. What could be holding it down? Any suggestions on what the installers may have used to stick it down with may help in finding a solvent or other means to release it from its mooring.
  • Soko42vv Dec 29, 2008
    Just what I was thinking. I already got out my thin razor knife to cut through whatever adhesive might be there. Wish me luck. I did check carefully for any mounting bolts and there aren't any to be found. As a matter of fact the instructions for the Jenn Air don't even call for any mounting hardware. Thank you also for the gas line watch out. That was the first thing I did even before purchasing the new unit so I'm good on that front.
    Thanks again for your help. I did not expect an answer that quickly.
  • 318 Answers
Alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Posted on Dec 29, 2008
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Left a empty pan on hot burner and glass top turned smokey under glass and left tiny pit marks on surface the color of the top is black
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Amana AKT3650 Electric Cooktop
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Burner out in whirpool black glass cooktop
take the whole cooktop out there should be screws around the base you take them out, seperate the bottom from the glass you should be able to get to the element to check if it is bad by ohming it out
May 01, 2009 | Cooktops
Dual Surface Selector Switch
more common is the dual switch to be bad, but it is possible that the elemnt itself has burnt out, usually a 5 yr warr on the elemnts under glass
Nov 08, 2008 | GE Profile JP930 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
502 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
