Aspire 9300 keyboard removal
Can you call me please? Would appreciate it. Kevin 803-554-3040
  • Anonymous Feb 18, 2009
    how to dismantle?
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
My internal fan isnt working, want to know how to get to it to clean it please.
Usally you pop out the keyboard and the palastic between keyboard and screen. At that point you would see the cpu and fan..
Feb 25, 2010 | Acer Aspire 9300 Notebook
Instructions on how to remove and replace a keyboard acer 9300
Unplug computer>power down> remove battery>remove all screws on exterior housing> remove internal screws> disconnect the wire/cable from keyboard>remove keyboard.
Jan 12, 2010 | Acer Aspire 9300-3716 Notebook
Replacing keyboard on acer aspire 9300
there are some screws in the hinge cover that pops out in most laptops , then a few screws to remove keyboard, and the cable attaching keyboard to motherboard , a clip to lift up
Jul 19, 2009 | Acer Computers & Internet
Acer 9300 aspire resolution problems.
Hi, Thank You For Choosing FixYa!!!
If you Wish. I will take remote Control of your computer and I will try to Fix it.
Thanks, PREM
Mar 13, 2009 | Acer Aspire 9300 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Replacing a back cover on Acer Aspire 9300
This link shows how to take apart an ACER 5100, which is a similar procedure to dissasemble your laptop. Once you get the screen out you'll see how to finish the repair.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 09, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 - Broken DC Charging Jack Socket
You will need to disconnect these. Then you will locate the five metal tabs along the back, which need to be pressed in, which releases the top part of the keyboard and it will now come out. Then re assemble connectors through the access holes you will now see very tricky job more plug connectors inside to so go carefull make sure you disconnect these correctly as you may pull the wires out
Dec 17, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 9300 Keyboard replacement
I have the Acer 9000/7000 pdf service manual if anyone would like it.
You may contact me at jonyjams @ hotmail.com (take the spaces out before and after the @ sign)
Dec 04, 2008 | Acer Aspire 9300 Notebook
How to remove case from acer aspire 9300
Hi, your best bet is to remove the keyboard first, you will find other screws underneath which hold in the bottom section.
Have a good new year
John
Dec 29, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
