Question about True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
True commercial freezer
Freezer not freezing, ice on coils,temp is keeping around 30-31
  • 4 more comments
  • Anonymous Feb 21, 2008
    We had this problem -- technician came out and reset the defrost clock...he said it was a common problem with True units where the clock pulls out of defrost cycle too soon which freezes up the system.
  • Anonymous Apr 24, 2008
    We have a P1 fault code flashing on a Freezer can someone tell me what it is telling us is wrong
    True T-52F freezer thanks
  • Anonymous Jun 04, 2008
    My True commercial freezer is running constantly without cutting out. When I unplug it and thaw it for a few hours it seems to work again for a short period then the same thing happens again!
  • neru7 Aug 27, 2008
    Freezer is only reaching temp of 30 degrees. Tech. has replaced thaw swith that was stuck, checked fans and is now detecting a freeon leak in the back panel. there is not evidence a leak any where else.
  • kiamarz_a Aug 28, 2008
    The compressor fan works, but the compressor does not. The compressor gets warm after about 15 minutes.
  • Anonymous Mar 20, 2014
    I set the temp control to max still won't freeze
    Novelist:
  • 116 Answers
The ice could be preventing the freezer from freezing properly, try defrosting the unit. if this does not help then this could indicate a more serious problem like a bad temp sensor or refrigerant leak.
Posted on Apr 27, 2007
Coils ice up
My best guess is that the drain has some debris in it and the defrosted water from the coil is being picked up and being re-frozen against the coil and freezing up the drain pan. The defrost timer may have failed, the defrost termination button fastened to the coil may have failed, the defrost heater on the coil itself may have separated from the coil or just outright failed. Hope this helps and good luck.
Sep 22, 2014 | True 49 cu. ft. / 1388 liter Commercial...
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
My true freezer temperature gage has a P1 flashing code
If unit keeps proper temp. then I would think that either the thermometer sensing probe may have been damaged during the repair process or the thermometer itself has failed.
May 13, 2010 | True Commercial Freezer TM74F
Can anyone tell me what My Kenmore upright freezer 20cu ft should be at? temperature I mean?
Freezer temps can very, but as we know freezer temps can run from +32F to -40 or more on commercial boxes with the different freons. But back to you, I would say from my charts on low, med., temp refrigerators, you should be around +8F to -5F. When I mentioned +32, we know that's when water starts to freeze, so you want the freezer to be much colder then that.In order to keep ice-cream frozen, you must cycle around -5f to -10f.I sincerely hopes this has helped you out, as you will I am sure get many different opinions, but +8 to-5 is excellent for this box.
Sincerely,
Shastalaker7
Nov 16, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The freezer will not freeze or keep its
Check to condenser coil and make sure it is clean and the fan near it is running when the compressor is on. Check for ice build up in the freezer. If the evaporator coil is iced up the box will run warm. It may be a defrost problem, a dirty condenser, or a refrigerant issue.
Nov 01, 2009 | Continental Freezer Wide Freezer low temp...
We have a true T49F freezer and the evaporator fans are not running. The compressor is running on startup. The coils are cold. But are freezing up. Shouldn't the fan be on, or does the cabinet have to...
Freezers have a sensor that is referred to as a "Fan Delay/Defrost Terminator". It senses the temp during the defrost cycle. Usually, when the evap temp reaches about 50 degrees, there should not be any frost or ice on it. This device terminates the defrost cycle. It also keeps the fans off so warm air is not circulated. When the evap gets to about 20 degress or so, the sensor switches on the evap fans. If the fans are not coming on, either the sensor is bad or the evap is not reaching the proper temp to cause the sensor to turn on the fans.
Hope is helps to clear up some things and point you in a direction as to what might be going on.
Jul 12, 2009 | True 49 cu. ft. / 1388 liter Commercial...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F Logo
390 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
