Question about IBM Iomega ZIP 750 (22P7099) External ZIP Drive
Use of zip drive
I have a clone pc that is unable to write to my d: drive (cd). If I purchase a zip drive should I be able to copy the files I need to that so I can use the information on another pc? (Is this the same as an external hard drive?0
  • 93 Answers
Yes u can
Posted on Dec 29, 2008
Unable to do install of XP. during install process pc reports unable to copy various .dll's and other files from install disk. install disk is in perfect condition.
The message refers to the CD/DVD drive being unable to read from the CD itself. That could mean that either the disk is in bad condition and cannot be read (i.e. scratches, old disk, etc) OR that the drive has difficulty reading from the disk.
In the later case, it's the drive's fault and not the disk's (since you mention it's in perfect condition).
You could try cleaning up the drive but it's usually not worth it and since they're quite cheap, I would recommend getting a new DVD drive instead.
Hope that helps!
Mar 13, 2011 | AcerPower S285 (APS285UC3521) PC Desktop
Medion MIM2080 MD95408 Original 40gb hard drive has died. Purchased 80gb replacement. Have cloned WIN_XP_PRO from another device onto new hard drive. When laptop boots all you get is a black screen...
did you get all the files? most likely there is a corrupt or missing set of files in the cloned files
i suggest you either get a new hard copy (disks) and install from there or use linux (most linux OS's are free online)
Nov 16, 2010 | Computers & Internet
Im trying to clone my old hd to my new seagate 4oogb EID both are eid interface hds but I need to no where to place the jumper on the seagate? and when i try to clone it says unable to lock volume on the...
are you trying to do this using while using your os? if so i would try downloading partition magic, it is saying unable to lock volume because your currently using it e.g. your os is installed on the drive, and it cant lock your os when your using it at the same time.
Nov 02, 2010 | Seagate Barracuda 250 GB EIDE Hard Drive
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Oct 30, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Trying to clone my hard drive: it shows 2 files FAT and NTFS
Cloning a drive cant be done very easily manually, you have to replicate the MBR, the boot files to the start of the drive and copy the system files in the correct manor.
Alternativly, you can read this blog that explains about some free tool
http://simontodd.com/2010/02/free-hard-drive-cloning-tools/
Feb 04, 2010 | Microsoft Windows XP Professional Full...
I'm trying to move pictures from a cd to my dell laptop
You'll need to download the images onto your laptop before you can send them. Copy them to a newly created folder on your desktop. Once you have moved them you should zip the folder with Winzip, or another program on your laptop that will compress your images into a zip file. When your zip file is created you can attach it to your email. Be sure your file isn't too large or it will never send. You may have to break up your images into smaller files.
Jul 27, 2009 | Dell Computers & Internet
Want to use clone hard drive to run XP
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Unable to copy files to cd
sounds like the optics in the CD drive have bit the dust. replace your drive. you can get one for cheap at any computer store
Mar 27, 2009 | Dell OptiPlex GX270 PC Desktop
Boot sector virus
Hi, regardless of the amount of users on the pc, the virus is resident in the pc, not a persons profile. Bad news is the only way of 100% resolving this is by a fresh install of the operating system. Place the operating disk in the cd drive, shut down and reboot, click fresh install from the options that are presented to you.
Jul 18, 2008 | Computers & Internet
Forgot Administrative pw
make a dos bootable floppy or pen drive or Cd which one does your computer supports and download password remover software from htttp://www.yogesm.110mb.com/PWDCHANGER.zip. extract zip file and copy the file to the bootable CD, pen drive or floppy drive and boot your computer from bootable cd, or floppy which we made.and run the pwdchanger.exe file in dos mode and follow the instructions
Jun 25, 2008 | HP Compaq Presario SR2150NX PC Desktop
IBM Iomega ZIP 750 (22P7099) External ZIP Drive Logo
615 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
