Question about Psi Blue Max 2200 High Pressure Gas Power Washer
My pull cord broke how do I fix this
I need to know how to repair pull cord
  • jramirezbrit Apr 19, 2009
    pull cord and spring broke where do i get the starter assembly
  • David Ford
    David Ford May 11, 2010
    On your starter housing does it have 3 or 4 screws holding it to the cover? Or do you have to remove the whole cover assembly? Let me know. If only the starter rope broke its not that hard but I need that info to help you.
Pull cord stuck open
Most likely the recoil spring broke. The engine cover has to be removed to repair this. If you are not mechanically inclined, it would be best to take it to a local small engine repair shop. Proper replacement involves knowing how many pre-wind rotations is required to properly recoil the rope. Some things are just better left to the pros.
Aug 23, 2014 | Garden
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
Broken pull cord
Pull cords can be purchased from your local hardware stores. If the handle just broke off, and the cord is fine, the handle itself can be replaced.
If you are uncomfortable performing the work, just look for 'small engine repair' places in your yellow pages.
Jul 10, 2012 | Honda Garden
Have an Excell 2500, VR2522...... Pull cord broke and now i think the spring is broke; where can I get a new spring and directions to reassemble the pull start?
That pressure washer uses a Honda 5.5 hp overhead cam engine
You need to get the model number of the Honda Engine and then Click Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Jun 23, 2011 | Garden
I have honda gcv160 5.5 pressure washer, after sitting over winter, I went to use it, and I can't even pull the cord to try and start it. What are any reccomendations as to what I can do to fix this?
My power washer started doing that after the pull-cord mechanism broke.
I took off the hoses to make sure there was no back-pressure caused by the pump.
And pull rope was still frozen.
We took off the pull rope cover on top of the machine.
The cover came off easy.
After that we lifted out the spring-pulley where the rope is attached the spring unwound and we couldn't get it back together so I bought another one.
We should not have lifted it out ... we should have tried to get it to move first without lifting it up.
In any case the washer worked fine after the replacement.
When you store a power washer, be sure to drain the water and disconnect the hoses.
Don't leave any gasoline in the engine or it will gum up the carburetor.
Never turn a gasoline engine on its side or upside down or the oil will run into carburetor, and carburetor will need work.
Nov 09, 2010 | Garden
The pull cord on my pressurewasher just broke How do I fix it?
Usually you have to take the shroud that contains the recoil starter assembly off to get to it. You may have to take it apart to fix the rope. If it broke on the end nearest the starter, you probably have enough rope left to reuse it. Usually they break right at the starter, due the the constant bending and rubbing. Pay attention to how it comes apart, and make sure to rewind your spring before putting the rope back on the pulley, otherwise it will not wind back up.
Apr 24, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Pull cord stuck on my pressure washer.
Need to remove assembly to find problem.
Mar 10, 2010 | Briggs & Stratton Garden
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
1,662 people viewed this question
Top Psi Garden Experts
John Trevino
Fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
