Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher---water filling from the bottom when off?
It appears our Bosch dishwasher has a slow leak, where water appears to be gathering in the bottom of the dishwasher to the point where if we don't use it for 24 hours, the whole bottom of the dishwasher will be filled with several inches of water. Any help would be appreciated!
  • mrsensible Mar 24, 2009
    Bosch dishwasher started to leak from front door seal. After turning machine off, i noticed the bottom was filled with dirty water which has not drained away. Possible waste pump failure or pipe blockage ?
    Sergeant:
    Champion:
  • 338 Answers
I would replace the inlet valve. it sounds like it is not closing all the way
Posted on Dec 29, 2008
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
I have an older model Bosch dishwasher, model SHX46B, serial 830300124, that is leaking while not in operation. It's a very slow leak, and I think I heard and saw a drip from the upper spray arm. It fills...
Hi.
Sounds like a leaky inlet valve. Sometimes they don't seal off completely or the membrane inside it could be torn. Best to replace the whole valve.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My bosch dishwasher will not fill with water. I have manually filled it but it just pumps it out when I switch it on.
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Feb 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water leaking from the bottom of the dishwasher.
ck the float it may be comming under the door . if water is still in tank after cycle / clean the screen in the bottom it is a lift out basket . ck for resstriction in drain line . all of thes will cause over fill and flooding . your model may have a pressure sw . sometimes food gets in the air line / remove tube and blow out .. mm
Dec 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
432 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
