Question about New Home HF-2022
How to thread a Janome/New Home XR-VII
Hi I just bought a Janome XR-VII from an op shop (in Australia) and can't quite figure how to thread it (what looks good doesn't run smooth but builds tension on the thread. The bobbin runs smooth. nothing seems jammed or tight when the needle is not threaded. I can spool up a bobbin ok too.
I don't much about this at all - had my step-mother and sister look at the machine over Christmas. The info above is their summary. I can't find a manual for this online - except maybe from the UK, but with exchange rates it is an expensive way to even find out if the machine is worth keeping.
So... does anyone know the correct way to thread up this model? I'm happy to buy a manual once I know the machine is worth keeping.
Cheers
Neil
South East Queensland, Australia
4 Suggested Answers
  • 43 Answers
SOURCE: I would like to know correct way to thread needle,
Find the threading instructions for your Janome by clicking to this link in my business web site: http://www.sewvac1.com/Janome_632_Threading.pdf
Posted on May 07, 2009
  • 240 Answers
SOURCE: The needle doesn't catch the thread in the bobbin
Are you certain the needle is not bent and that it is in the right way around? Which model is it?(I used to sell them)
Posted on Jun 21, 2009
SOURCE: New Home sewing maching, using
1.put new spool of thread on
2.watch the thread on the take up lever,make sure it doesn't come off
3.check the tension disk for loose threads, if there are threads pull out
4.check needle for being bent or blunt --if so replace
Posted on Jul 29, 2010
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Janome New Home sewing machine instruction manuals
Make It Handmade Threading Your Serger or Overlocker
Nov 25, 2016 | New Home Sewing Machines
I need an instruction manual for an old Janome sewing machine.
you can search Google for a make,model,manual .GOOD LUCK and print one that looks real close to your machine .
Nov 12, 2015 | Janome Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
I need an owners manual for a Janome XR-VII (990) any suggestions?? I've searched the net with no luck!
I've looked also, here are some sites you'll have to EMAIL them
about the manual
sewvacdoctor.com
a1sewingmachines.com
sewusa.com
Jun 07, 2012 | Janome Sewing Machines
I have a New Home xr-vii sewing machine, the balance wheel is very hard to turn. The repair shop I took it to said the clutch needed to be adjusted. Got it back 8 months later and it still has the s
if the sewing machine repair shop knew the machine needed a clutch
adjustment, then why didn't they fix it. or if they said they did & it's not
fixed, I'd call them & ask them why the machine is still doing the same
as it did?
May 03, 2012 | Sewing Machines
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
How do you thread a bobbin on the SEW PETITE. I'm trying to figure out how to use the bobbin, I have thread the needle but I don't know how to do the bobbin! Help Kat
I had the same problem at first, but this video explained it quite well for me. Good luck. http://stamptv.ning.com/video/janome-sewmini-part-2-bobbin
Oct 28, 2009 | Janome Sewing Machines
Machine suddenly became noisy on sewing
Thanks. As no one had replied (it's been 8 months) I took this back to the shop I bought it from and they fixed under warranty.
Apr 24, 2007 | Janome 4623 Mechanical Sewing Machine
New Home HF-2022 Logo
604 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
