IT TURNS BUT NO HEAT COMES OUT, COULD IT BE HEATING ELEMENT. IT NOT WHAT COULD IT BE, IT'S NOT VERY OLD
MODEL NUMBER EED4400SQ
You might have a high limit or thermal fuse that has failed due to overheating. these will go bad when there is a lack of air flow, probably from a pinched off or plugged vent. it could be a bad element but not as likely as the thermostats. if you can get the element housing out and check all of them with a VOM meter, it will show you which one has an "open" circuit.
