Question about E-Mu 1616M Sound Card
EMU 1616M sound card
My laptop recognizes the soundcard,and the plugins work on cubase. But, the monitors I have connected to the EMU have no sound coming out, only sound comes from the laptop speakers.
  • edub629 Jan 14, 2009
    have a similar issue.. the main mix shows me that sound is being generated but it does not make it to any of the 3 outputs... my speakers work thats not the issue. is this a physical hardware breakage issue or is it a software driver thing..
    btw i have vista and it was working fine until i turned my comp off for awhile and unplugged everything including my pci card.
    an by awhile i mean like 6-10 hours... not a matter of days or weeks.
  • 827 Answers
I know this is a longshot, so forgive me..
Hit F8 on booting up and go into the BIOS, and use the arrow keys to navigate to sound and check that the PCI (sound card) is checked and not the OS (onboard sound). Save to CMOS and Exit.
I know.. I know.. but sometimes it's as simple as that..
Let me know how you get on..
Chris (ziraffa)
Posted on Dec 29, 2008
I have the E-MU system installed on a windows 7 machine. the EMU applications picks up signal from the mike but none of the sound programs installed on the machine do. Any ideas?
1. Check for update for you sound card at the manufacturers site this may be the issue.
Some sound cards will not be fully recognized by Windows 7 because the manufacturer has not given or developed a full driver set for the new Windows environment.
Apr 16, 2010 | E-Mu 1616M Sound Card
CANT GET MY EMU 0404 USB TO RECORD !!!!
you need to update yo sound card with vista
Jan 20, 2010 | E-Mu 0404 Sound Card
EMU 1616 + vaio = BSOD
You need combofix utility, first install on your os and then run it. After complete the process take a reboot and then try to reinstall the driver, your BSOD problem will have been removed.
Good Luck
Dec 08, 2009 | E-Mu 1616M Sound Card
I can't get the software/drivers to download to my PC (Dell GX280 w/3gb ram XPpro). I'm trying to use the bundle that came with the purchase of my 1616m and I get a message that says it doesn't see any emu...
Try removing the device driver in Hardware manager, then 'refresh' to tell it to look for a new driver. Keep the CD in the drive, and have windows search it for the driver.
Oct 24, 2009 | E-Mu EMU 1820 24 Bit 192K Interface with 2...
Us-144 working only on high latency!
Even my q6600 clocked at 3.6 Ghz gives me 12ms latency. It turns out the tascam highest latency is 12ms also on my p3 3.0 ghz pc. I haven't tried the tascam on my q6600 - I use an Emu 1820m on that. But try testing the tascam on a really fast computer. It's probably your dell's middling motherboard that's the slow down as well as all the extra stuff installed on dell's and especially notebooks that are robbing the usb bus of it's bandwidth. In most cases with the tascam, it's the pc or a low latency setting. If you want a great card for serious work: The EMU 1616m pcmcia card is a great card! Even SoundonSound loves them. Emu just makes great soundcards that rival any card out there for the best prices. Emu also gives the most control via it's excellent PatchMix software, but Patchmix does require an average IQ and about 10 minutes of reading.
Jan 05, 2009 | Tascam US-144 Sound Card
HI, I have an emu 1616m soundcard. My laptop recognizes the EMU and the pulgins, but no sound comes out of the monitors.Only from the laptop speakers.
You have to select the EMU as the default playback device in Windows and or select it as the playback device in the software you are using for recording or playback.
Go to Control Panel and Sound and Audio Devices icon, and select the Audio tab. There is a drop down box that lists all playback devices. You have to select the EMU in there.
That should get you working.
Dec 29, 2008 | E-Mu 1616M Sound Card
Emu 1616 pci for mac!
No they don't support the 1616 or 1616m on mac yet. As far as I know only some USB interfaces are supported.
May 13, 2008 | E-Mu 1616M Sound Card
EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Mar 19, 2008 | E-Mu 1616M Sound Card
Loading problem emu1616
First up, I am no expert, but hope I can help.
I think that it is just a matter of following the installation procedures which EMU describe in the booklet.
When you insert the card for the first time, do not install using the hardware wizard.
Instead exit out of it and insert the cd, which will run a seperate install procedure (if autorun is enabled).
During the installation, a splashscreen will pop up (at around 45% complete) saying that the driver is not signed. Choose 'continue anyway'.
This should take care of the digital signature issue.
After this, there might be a problem with the cardbus controller.
This is highlighted on the EMU website.
Thats the problem which I am struggling with and hope someone can help out ..
Dec 10, 2007 | E-Mu 1616M Sound Card
Open Questions:
E-Mu 1616M Sound Card Logo
151 people viewed this question
Top E-Mu Computers & Internet Experts
David
David
Willem.
Willem.
Steve
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
