Question about Pioneer PDP-5070HD 50 in. Plasma Television
No picture or sound from the HDMI input 5 or input 6
Pioneer PDP-5070HD. DVD works. Cable works (input 3) but no picture or sound from the HDMI input 5 or input 6.
5 Suggested Answers
  • 208 Answers
SOURCE: hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Posted on Feb 05, 2008
SOURCE: HDMI inputs on my PDP-R04U are not working
From home set up on remote, choose option, enable HDMI.
Posted on Dec 17, 2008
  • 41 Answers
SOURCE: Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Posted on Mar 29, 2009
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Dec 02, 2013 | Pioneer Televison & Video
Screen says: Caution, no input.
What kind of cable is this? Component, Composite, HDMI? Try a different cable. Also, ensure you have the cable properly connected and that the TV is on the right input setting.
Nov 10, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
3 Press /  to select “HDMI Input”, and then press
4 Press /  to select “Setting”, and then press
5 Press /  to select “Enable”, and then press
there you go
Sep 04, 2008 | Televison & Video
Pioneer 5070HD, Onkyo TX-SR605S receiver and Cyberhome DVR 1500 connection
you may have fixed your dvr1500 by now but i just came across your signal problem today,so if it is still not working try putting a cable from the yellow video out of your 1500 to tv video in ,switch to this input on your tv and you should get a picture.after this is done set output on 1500 to composite and put into cbl/sat on amp,put hdmi cable from tv into hd out on amp, go to setup input assignment ,click on this to get monitor out,click again you get hdmi mntr flick right to switch on,put your tv to hdmi and you should have a picture.
hope this helped.
cable guy.
Sep 17, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Pioneer PDP-5070HD 50 in. Plasma Television Logo
83 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
