Question about Sony Cyber-shot DSC-W100 Digital Camera
LCD display is white
I cannot see images in the LCD display, because its all white. I can use the machine using the optical visor, and I can also take pictures. It doesn't matter if I turn the camera off and on several times, the problem remains and I also tried to swuitch the mode, and press all the buttons. It is noy a memory stick or charge problem. Don't known what to do, the camera is brand new. Help please !!
    Novelist:
  • 198 Answers
Hello dieguito, First of all the display is white most probably because it doesn't receive singnals from the mainboard. What you see is actually the led backlight of the display. Without any signals these displays are white, and when signal is applied the transistors that form the actual tft (thin film transistor) pannel opose light on different wave lenghts in order to achive different colors. The signal is fed into the display via a data cable and that's where the problem could be, it may not make a perfect electric connection. Another case would be that the camera's firmware got corrupted and needs to be re-written. However if your camera is new, i suggest you take it for an in warranty check at a service center. The first option will require dissasembling your camera and the second one writting a special software onto it. The W series are known to have some problems with the screen but their firmware (it's bassicaly the same as w70 or w50) is pretty firmly placed, i haven't seen cases of it to mailfunction, i suspect the first case, involving a connector with the display. Good luck and please post back if you need more info.
Posted on Apr 27, 2007
Why is display information having a ghost like after image when the camera is turned?
Perhaps some moist came behind the glass? perhaps some air? Try to live with it, because the result is what counts and the pictures don't have this problem. I think it will cost far to much to bring it to a service or repair centre. Use the money to buy a new camera what this no longer shoot pictures.
May 18, 2014 | Fuji Finepix S3200 14. Mp 24x Wide Angle...
Shutter Priority Problem - photo is just a white image
sounds like an iso issue. its a pain but try to write down all your current settings then try resetting in the menu. and try applying all your previous recent settings one by one in shutter priority mode and take a pic before applying each one to see what tips the camera to react the way it has, long process but not sure its a camera issue more just a setting
May 16, 2012 | GE X500 16MP 15x Optical/6x Digital Zoom...
When i turn on my camera the screen is on but white and shows no image..and the little round light goes orange,,is it worth getting mended
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the memory card on your PC. If the images shot are seen to be clear on the PC , then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using fixya
Sep 03, 2011 | Hitachi Computers & Internet
I need a manual for vivtiar 3188
Product MPN MPN: 80640 Key Features Features: Red-eye Correction Camera Type: Compact Resolution: 3.1 Megapixel LCD Screen Size: 1.5 in. Optical Zoom: Without Optical Zoom Digital Zoom: 4x Lens Interchangeable Lens: Not Interchangeable Lenses Optical Zoom: Without Optical Zoom Focus Type: Autofocus Macro Focus Range: 7.87 - 11.81 in. (w) Focal Length: 6.1 - 18.3 mm Image Quality Image Sensor Type: CMOS Camera Resolution: 3.1 Megapixel Image Resolutions: 2560 x 1920 · 2048 x 1536 · 1600 x 1200 Video Video Resolutions: 640 x 480 (VGA) Video Speed: 15 fps Video Format: AVI Exposure Control Aperture Range: f2.8/f4.8 (w/t) White Balance: Auto · Daylight / Sunny (Preset) · Cloudy (Preset) · Fluorescent (Preset) · Tungsten (Preset) Storage Memory Type: Built-in · SD Card Built-in Memory Size: 16 MB Compression Type: JPEG Flash Flash Type: Built-In Flash Functions: Flash Off · Auto Flash · Forced On Viewfinder / Display LCD Protected Position: Without LCD Protected Position Interfaces Interface Type: USB 1.1 Video Interface: Video Out Power Supply Battery Type: 2 x AAA Batteries Included Features Built-in Microphone: With Built-in Microphone System Requirements Operating System: Microsoft Windows 2000 · Microsoft Windows 98SE · Microsoft Windows ME · Microsoft Windows XP Dimensions Width: 3.5 in. Depth: 0.8 in. Height: 2.44 in. Miscellaneous Family Line: Vivitar ViviCam UPC: 19643806405 Product ID: 44609540 Return to top
Aug 30, 2011 | Cameras
The problem is, my screen in the camera mode turns completely white. i can see the display options but not the scenery of the picture i want to click. if i click, the picture is simply an empty white...
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort.
Finally a fault on the control unit can be that the image is not processed.
Jul 25, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
LCD SCREEN
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
Mar 11, 2008 | Fuji FinePix A345 Digital Camera
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Telephoto images
The D-595 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Telephoto images
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
