Question about Dishwashers
Grinding/Rubbing noise? My GE Potscrubber 650 just started making a weird grinding/rubbing noise. It went through the cycles just fine except for this new noise.
  • mgr1999 Dec 30, 2008
    Worked like a charm. Interesting things came out of the sump- the culprit was a hard plastic tube/straw of some kind. Thank you!
  • 318 Answers
The unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
Posted on Dec 29, 2008
Ceiling fan making grinding noise
bearings are dry and noise is metal on metal you can try to oil/lube the bearings --and or a blade is rubbing on case either loose blade or bearings worn causing offset wobble
Jul 13, 2016 | Dryers
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Grinding washing machine agitator
more than likely the pump is the part that is making the noise. You can verify this by leaning the machine back where you can see the pulleys, your pump will be the one in the back. Remove the belt and each pulley should turn smoothly. The part number for the pump is 35-6780
May 28, 2012 | Maytag Washing Machines
My ge wvsr1060 makes a grinding sound only while agitating. What is wrong & how can I fix it?
The scraping or grinding noise is from the drive pulley rubbing on the base. This could from the front apron sagging.This can be accessed by removing the front cover.
Mar 02, 2010 | GE Washing Machines
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
GE Washer Tub has sunk and is grinding on bottom
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
May 20, 2009 | GE Washing Machines
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Dishwashers Logo
383 people viewed this question
Top Dishwashers Experts
