Question about Pentax Optio W10 Digital Camera
Can't remove lock logo on screen
A lock logo comes up on my screen when selecting "menu" or "mode". Which means i cannot change the settings e.g from movie mode to still mode. I cannot find my manual to work out how to take the lock off and have no idea how it got there in the first place. Any suggestions????
I just had the same problem had to go on line and read the manual. Manual can be found on this link if you have any other problems. http://www.retrevo.com/search/fv/3bbf321a136686863b8bb2fcf91b0aa6.pdf#page=1 Anyway your camera is probably in green mode all you have to do is turn on the camera and and press and release the trash button that has the green dot on it. Then you are all set.
Posted on Sep 26, 2007
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Unlocking LG KG800
Do you mean unlocking the phone screen (like you forgot your security password), or unlocking the phone to use a SIM from a different network?
Jul 16, 2008 | Lands Phones
Tip
How to Put iPod into Disk Mode
Putting iPods with a Click Wheel into disk mode
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
on Apr 15, 2010 | Computers & Internet
How to activate safe mode on acer aspire
press f5 at acer logo appear at start up, then chose safe mode
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | Acer Aspire 3623WXCi Notebook
I have 5 Dell 4310 WX projecors and I would like to display my logo when they start-up. Can this be done with the projector only or is a laptop necessary for this to happen?
I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
Jan 14, 2010 | Compaq Presario M2000 Notebook
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
May 05, 2009 | Apple iPod nano 3rd Generation
My 30g ipod is stuck in the restore mode. i follow the instructions on how to restore it, and everytime i plug it into the computer, it says it needs to be restored. how do i get it out of the restore...
Try this out: And let me know the status
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then try restoring the ipod using Itunes...
Feb 23, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod shows the help screen with a website
Try thisout and restore th ipod
Feb 08, 2009 | Apple iPod MA446LL/A MP3 Player
N keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
May 11, 2008 | Nokia 6230
Pentax Optio W10 Digital Camera Logo
127 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
