Question about Dell Dimension 8300 PC Desktop
Reinstall When I try to reinstall Microsoft Office Small Business Edition 2003 to my computer with the disk that came with the computer when I bought it, I get the message, ''This patch package could not be opened, verify that the package exist and that you an access it, or contatct the application vendor to verity that this is a valid windows installer patch package.''
  • 837 Answers
Everytime I open an excel file someting pop up...installing microsoft professional 2003 edition
Yes To Stop that try uninstalling Microsoft Office then reinstall on that particular profile
This Happens because u installed Microsoft Office on a different profile
May 29, 2011 | Microsoft Office Professional Edition 2003...
My computer crashed a few weeks ago. The docs
Try to reinstall it. Since you have the disk and key, it shouldn't be a problem. Check with Microsoft if it won't get up and running.
Apr 05, 2010 | Microsoft Office 2003 Basic Edition...
I have the Certificate of Authority for MS Office 97.2 Small Busihnes Edition. It has a product ID number but no product key. How do I reinstall it without the product key?
you can not reinstall the product without the key. There is no way. Instead, you can switch over to Open Office from www.openoffice.org. It is free and is compatible with MS Office.
Mar 31, 2010 | Microsoft Office 97 Small Business Edition...
Microsoft Office small Business Edition 2003 keeps installing whe
try to uninstall the software and then clear the registries using a registry scanner then try to install the later version. If this dosnt work use an antivirus or a spyware remover
Feb 02, 2009 | Microsoft Office 2003 Small Business...
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
When i open any excel folder ,windows installer comes,and then it says it will configure 2003 edition,and then it cannot find the path for network drive,,...but microsoft is installed in computer....
It may be that office was loaded onto the comptuer under a different user name and was not selected for all users. Thereby trying to find the files for you to use. Try running it as the administrator or reinstall it.
Dec 26, 2008 | Microsoft Office 2003 Professional Edition
Office 2003 Standard edition compatible w/ Small Business edition
Where were you saving the old Excel files to: c:\my documents for example. Is your new Excel saving or retrieving documents from the same location? If not, it will look like the old files are gone, when Excel is simply looking in the wrong place.
An installation won't wipe out data files--they're in two different locations. If you do a global wildcard search (*.xls) you will probably find them.
Dec 09, 2008 | Microsoft Office 2003 Small Business...
How do I reconfigure microsoft office standard edition 2003?
Try repairing your office installation. To do that you will go to your control panel and select Add Remove Programs. Find your Microsoft Office 2003 and click on it like you would remove it. There you should be able to select repair instead of remove. This will repair the installation and should fix your problem.
Nov 17, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Dell Dimension 8300 PC Desktop Logo
56 people viewed this question
Alun Cox
