Question about Ovens
EO F2 Lock message on oven panel
Re: Whirlpool Gold Oven, Model #GW395LEG20
I pushed the Timer "off" button, and it became inverted. We were able to get the button "out," but then when we turned the oven off, first it came back on at 350 degrees, then 500 degrees, then displayed the message "EO F2" with a lock icon. We can't find our user manual. How do we reset the system?
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Posted on Dec 29, 2008
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
Hi - I have a whirlpool gold series electric double oven. The error message is E1 F2. Anyone know how to fix this?
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Jan 05, 2011 | Whirlpool RBD305PD Electric Double Oven
I have a new Whirlpool Built-in electric wall oven. I just installed it. The read out says EO F2. What does that mean?
EO-F2 means shorted touchpad.
Try pressing the CANCEL button to see if this clears it otherwise you will need a replacement touchpad.
Dec 13, 2010 | Ovens
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Unable to clear error message on panel...oven not operating
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
May 08, 2008 | Ovens
Error message on Whirlpool Gold gastop range: E0 -F2-
It means "shorted keypad".
1. Disconnect power from oven for longer than 30 seconds.
2. Re-apply power and observe for longer than 5 minutes.
3. If failure remains, disconnect power, replace control, then
go back to step 2.
4. Unplug and replug membrane connector.
Dec 29, 2007 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
314 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
