Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42h81 2 green vertical lines, splitting the screen into 3 equal sections. Lines are about 3cm wide and run from top to bottom of screen. Also, white horizontal lines move randomly between these green lines, separately in the 3 sections. As it warms up the white lines grow in intensity and cover the entire screen.
I have a Toshiba 42H81 TV - does anyone know where the hyperboard module is located and/or a picture of the board? Many thanks.
Tim
Posted on Feb 02, 2008
    Sergeant:
    Champion:
  • 326 Answers
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Posted on Apr 27, 2007
How to fix green vertical lines on the left side of my 32" flat screen tv
If those are real fine lines all the way from top to bottom, that is a section that has failed. I don't believe there is a way to repair it.
Dec 13, 2016 | Televison & Video
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Vertical band on new monitor
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Nov 06, 2006 | Dell UltraSharp 1907FP 19" LCD Monitor
Toshiba 42H81 42" Rear Projection Television Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
