Question about Pioneer Televison & Video
TROUBLE TO GET VOLUME ON PIONEER PLASMA AXD1459
Need to get volume to work.No success with remote controll or manual access on television.
Emsy32
  • 3 Answers
SOURCE: How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Posted on Jan 05, 2008
  • 6 Answers
SOURCE: Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Posted on Apr 11, 2009
  • 4090 Answers
SOURCE: Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
Posted on Sep 18, 2009
SOURCE: Just purchased a Toshiba 32BV700B
try 1191
Posted on Sep 29, 2010
SOURCE: volume control problem.constantly having to ajust
Also have the same problem with ours - purchased a 55" lcd/hdtv and have to constantly adjust volume especially between commercials and programs. Can bearly hear the program turn it up and it blasts you out of your seat at commercial time. Had cable company out and it is definitely not the cable. Also have a problem with TV constantly shutting on & off. Does anyone have a solution???
Posted on Jan 19, 2011
Please help. I can't find the remote control code for a Pioneer TV.
record the model number of the remote and google codes ? Or you need to record the model number of the pioneer and order the correct remote
Dec 03, 2017 | Pioneer PRO-1150HD 50 in. Plasma...
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Need a remote control for Pioneer model PDP-503CMX
Here you go sir/mam
http://parts.pioneerelectronics.com/part.asp?productNum=AXD1459
Sep 24, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Cannot program sky remote to operate volume control on pioneer pdp-4270xd pioneer plasma 42". have tried using code 0707 as this is the nearest I can find.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0166
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Nov 28, 2008 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
No sound
maybe in your cable box
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Televison & Video Logo
73 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
