Question about Whirlpool GU2400XTPS Built-in Dishwasher
Top spinner The very top plastic spinner (looks like a hurricane icon on a weather map) keeps coming out when the washer is on. The part doesn't look broken, and when I try to plug it back in, it stays, albiet loosley. A little tug and I can pull it back out again. Any suggestions as to how I get this part to stay in better? Thanks!!!
  • flattejl Feb 20, 2009
    I found the plastic part that looks like a map of a huricane at the bottom of my dishwasher. We could not figure out where it goes so almost threw it out. Where does it go and how do I get it to stay in place? I looked up the part number on the internet and it said it was a Whirlpool spinner (part 3 8519736). Sounds like the same problem.
Hi - I have the same problem. I found a parts site that sells the spinner and the parts to hold it in place. Maybe your parts are broken. Read the customer review at the bottom. Anyways, maybe this will help. If nothing else, you know where to get the part if you need a new one. http://www.partselect.com/xq/aspx/Inventory.734590/qx/PartDetail.htm?SourceCode=1
Posted on Oct 10, 2007
Agitator not working but spinner is fine how can i fix myself?
the dog ears are wore out look at a vid on it type in dog ear re[placement washer perhaps that will lead you to one if you open the washer the center top of the agitator pull off the cap there should be a bolt head down there unscrew it and pull out the top area the dog ears will be there three little plastic thing looking like teardrops with small fins to catch the agitator to move it they are worn out cheap to replace
May 14, 2016 | Washing Machines
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Best weather apps out there. Any idea guys?
'Weather Channel' Being the No. 1 free weather app in the App Store comes with a bit of scrutiny. But what can I say? They are The Weather Channel, and they know what they
Sep 06, 2010 | iPhone Apps
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water won't go to the top spinners
there is probably food stuck in the spinner,
ive had to remove the spinners on my mind one a year, and use the pressure washer on them, to get out the small chucks of food, and or plastic pieces.
Yes i know we can rinse more, but hey no one is perfect :)
Aug 21, 2009 | Kenmore Dishwashers
Need to install a new top spinner on the roof of our dishwasher
the medium sized plastic piece slides into the spinner and you put it upto the manifold. you have to remove the manifold so that you can push the smaller piece of plastic through the top of the manifold into the medium sized piece which would be holding the spinner up.
Dec 18, 2008 | Dishwashers
GE Washing Machine
I dont kow what you mean about a spinner? If your talking about the part in the middle thats caled a agitator. If your washer is the model with the plastic tub the agitator pulls up from the bottom. And I have to tell you it is not a easy thing to pull out. The hard gritty substance could be from your water. You might want to have your water checked. Hope this helps you.
Jul 13, 2007 | GE WDSR2080D Top Load Washer
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
388 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
