Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
HOW DO I REMOVE PRINTHEAD AND REPLACE WITH A NEW ONE
NEED HELP TO REMOVE PRINTHEAD
  • kokrick Jan 07, 2009
    can not find instructions on how to replace print head
  • 837 Answers
  • Jay Glendenning
    Jay Glendenning Dec 29, 2008
    that is page 74 in the actual document .. page 78 if you input the page into the pdf viewer
You just sent me a replacement printer and the instructions asked me to remove the printhead. I do not get insturctions on how to do this by going rto www.kodak.com/go/printheadsupport. I have removed...
Well, I don't think FixYa sent you the new replacement, but it was supposed to be sent by Kodak I guess. Anyway, here's the instructions on how to remove/install or in other words, how to replace the printhead.
  1. Verify that the printer is turned on and there are no error conditions.
  2. Open the printer access door and allow the printhead carriage to move to the center position.
  3. Remove the black and color ink cartridges.
  4. Disconnect the printhead by pressing the button in the upper-left corner of the carriage, then remove the printhead.nonontech_386.jpg
  5. Insert the printhead into the carriage.
  6. Place your thumb over the target label and push in firmly with your right thumb until you hear a loud snap.
  8. Insert the color ink cartridge into the printhead.
  9. Press down on the color ink cartridge until you hear it click into position.
  10. Repeat Steps 8-9 for the black ink cartridge.
  11. Close the printhead access door.
*Follow upto step 5 to remove the printhead, I just included the remaining steps for your information.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I cant remove the old one to replace it with the new one i got.
what do you want remove the printhead or the ink cartridges?
If the ink cartridges you just need to press the tab of the ink cartridges the pull it upward.
Now if the printhead you need to press the small tab on the upper middle part of the printhead., this tab is hidden thats why is hard to see., theres also a small tab on the upper left of the printhead you just need to press it to remove the Printhead
Oct 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Trying to unistall the printhead on my 5300 printer
There is an instructions on how to remove the printhead on this website
Thanks
Aug 01, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Jun 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I remove old printhead and place a new one in printer?
I finally called Kodak at their 800 number and someone in New Delhi, India walked me through it.
May 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Wont print black
Ok. Remove both cartriges. Put them aside. Remove the new printhead from its bag and all the protection things. To remove the old one, press the button at the top left of the printhead. Put the new printhead in, secure it by pressing the sticker with the finger, and replace the cartriges and print the alignment page.
Mar 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I remove old printhead and install a new one?
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printhead needs replacing
The printhead is completely user replaceable and need no complicated instructions.
1. Remove the ink ribbon.
2. Looking from above, find a small shiny lever to the right of the printhead.
3. Lift the lever with your hand and remove the printhead by pulling it upwards (make sure the printer is cold).
4. Reverse the procedure to install the new printhead.
Be blessed.
Oct 31, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
