Question about Bosch KGU34641 Bottom Freezer Refrigerator
Fridge not working but freezer still working ok
My fridge has stopped working but the freezer section at the bottom works fine, i dont know where to start, what could it be?how can i fix it?
it doesnt seem to have a tempeature control just button on the top, one for min one for med and one for max, then a freezer sign (think its for defrosting but not sure) any ideas on how to check what the problem could be? its a servis refrigorator model-MO263S
CrazyLarry
  • 173 Answers
SOURCE: fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Posted on Aug 31, 2007
fridgetech
  • 473 Answers
SOURCE: Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Posted on Oct 07, 2007
SOURCE: FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Posted on Jul 18, 2008
Richie_asg1
  • 1036 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Posted on Sep 08, 2009
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Posted on Jul 08, 2010
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Apr 19, 2010 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Fridge is not cooling
if you found the coil iced up then there is a defrost problem check thethermodisc and defrost control board if you know the heater is ok
Jul 09, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Bosch KGU34641 Bottom Freezer Refrigerator Logo
49 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
