Question about Microwave Ovens
Stuck on but no power
Microwave (Sharp R-510HK) will turn on as soon as door is closed but does not heat anything. Pressing the stop/cancel button cannot power off but can clear the display if there are any numbers punched in. Pressing the start/minute-plus button has no effect and does not even beep. Previously, the 5 on the number pad has gone dead: no response or beep when pressed; but it is now ok. Thanks for any advice.
  • waixchan Jan 02, 2009
    Problem fixed, for now I guess. All the protective relays are good. The door microswitches had a little bit more play. A shim to lift up the switch a couple mm did the trick.
  • 326 Answers
It is the problem of the faulty heating element .the heating element needs to be replaced to solve this heating problem.
Posted on Dec 29, 2008
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
My Maytag Microwave, Model MMV 4205 BAS has an issue. As soon as you close the door, there is a humming sound. This is without pressing [Start] or entering any time. I have tried pressing the [Stop/Clear]...
did it come into contact with water at anytime, if yes than this is probably the reason ask an electrician to come and have a check or if it is working fine you can continue using but make sure that no liquid will spill over inside
May 12, 2011 | Maytag MMV4205 Microwave Oven
My sharp R1870 microwave/convestion oven turns
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
Apr 26, 2010 | Sharp R-1870 Convection/Microwave Oven
Sharp microwave oven model no. R-510HK Problem: Interlocking switch associated with the oven door open/close handle is defective. Where can I get a replacement - cost location? Thanks, Brian
The best place to order Sharp parts is Tritronics at
We have the full service manual and I've uploaded it to our site here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Sharp Microwave Ovens
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Wont heat items in the micro or convection
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Fan runs when door is closed, but no heat.
It's probably a bad door switch or switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Microwave Ovens Logo
110 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
