Question about Uniden BC72XLT Handheld Scanner
Program a new number
I cannot program the new number in have lost my book on the screen there is a little key that i carnt get of its like its lock on to that number thank you its is a uniden ubc57xlt
  • 8,197 Answers
Here are all the scanner manuals. unfortunately yours is not there. I would check the model # again with the ones on the list. Or look at one the is close to yours to figure it out. sorry I can not help anymore
http://www.uniden.com/index/manuals_results.cfm?cat=3
Good Luck.
Posted on Dec 29, 2008
I recently lost the keys to my 2005 BMW x5 and had a tow service open it up via the passenger front window. The lock switch will not work now. Is there a reset? I cannot activate a new key w/o it!
So more information is needed as a few things could be happening. Such as does the vehicle have keyless entry and a key fob, Also this vehicle may use what is called a master key which must be present when a new key is added. I am assuming you are trying to reprogram a new key and perhaps you are at the point of programming that requires locking or unlocking through the vehicle master (driver-door) switch. I posted a link to a couple ways to program a new key as more then one option exists for manual programming which is programming without a BMW scan tool. One other thing to check is the actual door that was opened, look closely at the latch and make sure it is not damaged and or a little lever may exist to disable the automatic lock unlock. If you see a little slot with a metal tab, that may need to be switched back to allow the lock to work. You can test this by using the key in the door to attempt to unlock it manually. http://www.programyourkeys.com/BMW_X5_Key_Remote_Control_Fob_Programming.html
Jan 05, 2016 | 2005 BMW X5 3.0i
HOW DO I FIX MY LOCKED ELECTRONIC SHARP REGISTER
If it is locked electronically, you need to enter a secret PIN number and press the clerk button to unlock it. It can be programmed for new PIN numbers if you have lost them. If the cash drawer is locked, you can buy a key from a Sharp dealer. You can't get keys cut.
Dec 26, 2014 | Retail Supplies
Change nsin alarm code
Any one got a instruction book for one of these alarms carnt find mine and carnt remember how to re program it
Nov 18, 2012 | House Brand 2x Intrud Alert House Alert...
Lost instructions to relock my weiserlock smartkey set... I have the small key to insert and another set of keys but don't know the procedure. Please help, Kim
if you want to program a new key to the lock ( rekey ) --- first, take your old key and put it into the lock, turn the key 1/4 turn clockwise, now take your little rekey tool and put into the small hole that is next to the key hole -- push hard, now remove the tool and then WITHOUT turning the key remove the key from the lock, now insert the new key into the lock and turn the key 1/4 turn counter clockwise --- the lock will now remember that key and the old key should not work.
c...
Jan 19, 2011 | Garden
I lost my ignition key what do I do
if it has an immobilizer u need to get a key cut for it and get it programed
Dec 27, 2010 | 1994 Ford Crown Victoria
I lost the only key for 2007 rx 350 got a new key how do i make it work.
you have to program the key to your car or else it wont work to program your gonna have to take it to a dealership or somewhere or someone that can program it for u
Sep 10, 2009 | 2008 Lexus Rx 350
My key fob wont lock or unlock and set the alarm anymore. I put a new battery in and everything!! HELP!
Sounds like you lost program, or a bad key fob. Either way, check with the Honda dealer.
Jul 14, 2009 | 2004 Honda Pilot
MSW3517 Book inside
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number.
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Apr 22, 2009 | Sentry Fireproof Safe
Lost keys need to make a new key
Hi my name is Allen!
Have you tried the Dealership, give them your vin number and they should be able to cut you a key through the code book, just tell them you lost your keys.
For further assistance contact me at FixYa!
Dec 30, 2008 | 1994 Jeep Cherokee Country
Uniden BC72XLT Handheld Scanner Logo
81 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
