Question about Mr. Coffee CGX20 12-Cup Coffee Maker
Mr Coffee CGX23 stopped brewing
Worked fine in the morning but the evening coffed would not brew. Unplugged and set up again and no luck.
SOURCE: set brew delay
Assuming you're talking about the FT series with the "delay brew" button and the 24 hour analog as opposed to digital clock, it's simple.
First, you have to have your correct time set. This is simple just press the hour button and then the minute button until the correct time is showing. Be sure to look for the AM PM indicator to make sure you're getting the desired time set.
Then press the delay brew button and use the same hour and minute buttons until you get the desired time (again watch for am/pm)
That's it.
Posted on Nov 14, 2008
cactus bob
  • 267 Answers
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Posted on Mar 01, 2009
SOURCE: Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
Posted on May 05, 2009
buffalonyman
  • 1865 Answers
SOURCE: Mr. Coffee FTX23 quit brewing
The heating element burned out, its a common problem. Mr. Coffee tend to leak, I've had several of them.
Posted on Jun 10, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
Mr. Coffee SKX23 will not brew. Worked fine yesterday and buttons/light works just fine. I noticed there were comments recommending running vinegar & water to clean the pump, but if it doesn't pump how...
There is a fusible link in the wires going into and out of the circuit board. If you have a continuity checker it's an easy fix with a new fusible link at Radio Shack for about $2.00. Soldering gun and some wire and you're good to go, if that's the problem.
Jan 22, 2015 | Mr. Coffee Coffee Makers & Espresso...
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Coffee pot just would not brew this morning, though it worked fine yesterday morning. I emptied it and started over 3 times. The lights come on but that is all that comes on.
Check the water level. Check to make sure that the coffee filter under basket is clean and not plugged. YOu can remove your filter, then take out the basket and clean it....when did you purchase the machine?
Aug 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Set brew delay
That's it.
Jul 09, 2008 | Mr. Coffee FTXSS23GTF Coffee Maker
Mr. Coffee CGX20 12-Cup Coffee Maker Logo
214 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
