Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
BOSCH AQ125FX TANKLESS WATER HEATER
The water heater won't ignite promptly. It takes turning on the water 5 to 10 times before it will ignite. It is 5 years old. It has worked great until last 6 months.
  • 2 more comments
  • debbie05 Feb 12, 2008
    having problem with the tank not igniting. have to push reset button at least once per day, this unit is an outdoor model
  • Anonymous Apr 19, 2008
    continue to get er code - what to do please
  • Sod Father Nov 12, 2008
    I have the same problem. The pilot does not go on all the time. Sometimes I have to turn the hot water on and off a few times at the faucet. I tried rebuilding the water valve. No luck. I tried replacing the piezo. No luck. I tried replacing the thermocouple. No luck. I tried replacing the pilot tube (assuming it had a clog). No luck. The only thing that seems to work right now is to unscrew the pilot from the burner assembly and just let it hang there an inch away from the burner. This seems to resolve the problem, but is, as you can imagine, not very safe. Short of replacing the electronics, I am at a loss of what would cause it.
    Having the pilot assembly sit 1" outside of the burner works, so I assume it has something to do with lack of oxygen or even a loose wire of some sort.
  • FlyGuy357 Mar 11, 2009
    Same for me. The vent fan starts when the hot water tap is turned on. The pilot does not light nor the burner start. Unfortunately, this is our only source for hot water so I need to get it fixed. Good luck with yours.
    1. Fan starts
    2. igniter does not spark
    3. Pilot doesn't light
    4. Wife yells
Well, after an hour of internet searching, I can give some real advice.
http://www.houseneeds.com/shop/HeatingProducts/WaterHeating/parts/bosch125fxbrasspartsbuy.asp
This website has excellent trouble shooting and illustrated parts breakdowns. They'll even place your parts order too.
For my AQ125FX the problem was the Electronics Control Box (PN 87007207011). I didn't have the 1.3 Volts DC required for the igniter. I also recommend that you check the Water Inlet Filter (PN 8700507059) for deposits and blockage. While there is no specified time change for the filter, I suggest that it be changed at least every 2 years (cheap insurance at $10 a filter). There is a Service / Replacement kit for the Water Inlet Valve (PN 8703406178) if you've got a gummed up valve but it should not be necessary if the following things happen when you turn on the hot water tap:
1. The Exhaust Fan Vent Motor starts
2. The Pressure Demand Micro Switch closes (this is the black device at the very bottom of the unit)
The key to this system is downstream water pressure (demand for hot water) and the Water Inlet Valve and Pressure Demand Micro switch is the heart with the Electronics Control Box being the brains. I hope this helps you with your Bosch Aquastar water heater.
Posted on Mar 12, 2009
    Novelist:
  • 116 Answers
These heaters work when a pressure drop is sensed in the water supply line. The pressure sensor is likely blocked with sediment from the city supply. You may want to call for service.
Posted on Apr 27, 2007
I am unable to locate the reset buttom . I have the AQ125FX if you could tell me where to locate it i would greatly appreiciate your expertise
Posted on Nov 02, 2008
I noticed mine does not ignite properly during the summer. I believe the incoming water temperature may be a factor.
Posted on Oct 22, 2007
I finally got a heating and plumbing guy to look at my water heater. Turns out the problem was with gas pressure. The pressure was very low coming into the house at at the appliance. He turned up the pressure on the regulator coming into the house and the water heater has been working just fine.
Posted on Mar 23, 2009
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
I have a Reliance 501 HWH, 15 yrs old. Nary a problem until now. Yesterday, HW was very hot. Today, no HW. I'm thinking of replacing both elements and thermostats due to the age. Sound reasonable?
At fifteen years of age it would be less cost over time and labor to replace the whole tank. How efficient is your old one and being it runs hot all the time you could have a tank that will not last very long anyway. Mine sprung a leak at 18 years and made a big mess.
May 15, 2014 | Reliance Water Heater #6-50-DJRT 50GAL...
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Sep 07, 2013 | Water Heaters
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
The water heater will cycle 5-6-7 times with no probles then it fails ignition. The water heater is a rheem 50 gal power vent 2. It is about 2 years old.
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Apr 13, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hot water heater doesn't work 2 years old
First I would check to be sure your propane tank(s) are not empty and valve is not turned off and that the required gas pressure is being delivered to the unit i.e. pressure line tubing is not kinked or leaking - pressure regulator is operating properly.
Another culprit could be the thermocouple is malfunctioning or is not positioned properly, hence not allowing it to sense the flame.
Feb 21, 2009 | Water Heaters
Takes long time to heat then goes from hot to cold.
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Feb 03, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
1,965 people viewed this question
Top Terminator Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
