Question about Amana ALG331RAW Gas Dryer
Squealing Noise from Amana ALG331RAW
After about 10 minutes it starts squealing. It started a few weeks ago and is getting louder. I have replaced the belt a few years ago so I think I can remember how to disassemble and reassemble but not sure how to identify the problem and fix.
  • djroselaw Dec 30, 2008
    Thanks. The idler pully was the problem. The nut that holds it onto the arm had come off and it was only being held in place by the belt tension but was loose enough to wobble around. It barely turned and had charred looking lubrication on the shaft and inside the bearing housing. I cleaned the burned carbon and dirt off these surfaces with WD-40 and a rag and then lubricated it with WD-40 and it spins like a top now. Re-installed and tightened that nut snug. No more squeeling. Thanks
  • Anonymous Apr 17, 2009
    **** xx
  • 318 Answers
These dryers have wheel like drum supports and the bronze bearing inside them will wear out causing noise. once you get the drum out, look at the belt idler pulley also it too has a bearing and either one can cause the noise.
if you can get inside the unit, and the bearings dont look worn/wobbly, then you may be able to just lubricate them and it should work for another year or two. if you can get new rollers and idler that would be best and should only cost about 15-20 bucks each.
Posted on Dec 29, 2008
1984 Yamaha Venture Squealing somewhere towards the front end of the bike.
Unhook the speedo cable at the wheel and zip tie it up somewhere safe so the cable doesn't fall out of the sheath, and test ride. If the squeal doesn't go away it's the speedometer gear or something else at the wheel. If it does go away the bearings in the speedo itself are drying out. You'd then have to pull the cluster, fit a pipe cap with a grease zerk threaded to it onto the back of the speedo, and grease with appropriate bearing grease which I believe is moly grease.
Jul 29, 2012 | Motorcycles
Is it my serpentine belt?
It is your AC clutch assembly or AC compressor.
Jun 21, 2012 | Lisle Serpentine Belt Tool & Accessories -...
Loud sound from the engin when start and agos after 10 minuts
What kind of noise ae you hearing ????,,,
If it is a screeching/squealing sound this might be the fan belt, which when it gets loose, can slip and squeal on the pulleys. It should just ned to retensioned or at worst case, replaced.....
If it is some other noise, please let me know and I will hope to identify it for you.
Nov 15, 2010 | 1997 Honda CR-V
There is a squealing noise when the dryer runs. The belt seems to work fine, but there is a whistling/squealing noise when the dryer is on
The drum rides on a pair of plastic glides in the front. They get thin and their bracket begins to rub the drum.
The rollers tend to get a little noisy in time. I use HVAC oil (zoom-oil from ace hardware) to lube them because it is temp resistant, won't disapate, and is non flammable.
May 01, 2010 | Amana ALG331RAW Gas Dryer
2002 Porsche Boxster - had squealing coming from
Mine did that off and on for a month with no other problems then it started making a loud suction noise and the check engine light came on. I took it to the dealer and they said the "oil separator" needed to be replaced.
After the repair I never heard the squealing again.
Apr 21, 2010 | 2002 Porsche Boxster
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
Dryer louder than used to be, does it need service?
The belt may be worn and squealing because it is slipping.  When it warms up it stops slipping.  It will have to be replaced soon. A worn bearing on a support wheel could also cause intermittent noise.
May 29, 2009 | Amana ALE643RB Electric Dryer
Dictaphone 2710 noise problem
This squealing noise is caused by the capstan motor. The bearings have dried up and it's metal on metal - causing an awful squealing noise. As soon as you put in a cassette, the motor begins to spin - causing the squealing noise.
Aug 11, 2008 | Dictaphone Audio Players & Recorders
Amana ALG331RAW Gas Dryer Logo
256 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
