Question about Plumbing
Faucet leak from the connection with spout.
I just install a brand new American Standard faucet. Two knots and center spouts that turn. No leak at the water lines, no leaks at the knots but water is shooting out of the connection between the spout and the plate. I try to turned the rings connect the spouts to the rest of the faucet as tight as reasonable but still same amounts of leak. I check and the connect have the require two O rings.
  • aminh_nguyen Dec 29, 2008
    Thanks. That's what I thought.
  • Anonymous Mar 24, 2014
    I installed a new Waltec Pioneer cartridge and it started leaking within a hour
    Scholar:
  • 68 Answers
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Posted on Dec 29, 2008
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
How do I replace a spout O-ring on an American Standard Jasmine Hi-Flow Kitchen Faucet, 3821.831 or .834. I'm trying to get the spout assembly off to get access to replace. Thanks in advance!
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
Jun 03, 2011 | American Standard Jasmine 3821.831.295...
I have an older American Standard kitchen faucet (installed around 1950) with a leaking spout. I have removed the spout, cleaned out all the old packing after removing the tempered steel split o-ring and...
If you have a payless cashways in your area they carry americanstd. faucets and plumbing fixtures.I think that some K-Mart and sears stores do also. Hope this helps you. Thanks
Dec 22, 2010 | American Standard 4275.550.002 ColonySoft...
Montuori2947@att.net
check hose to head connection ,i.e. spout.
Apr 14, 2010 | American Standard Kitchen Faucet 6310 020...
American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
American standard kitchen faucet white
sometimes hard to see. Might be on the underside of the spout or on the back side of the part of the spout that it connected to the faucet. OR just compare to pictures on American Standard website
Jun 05, 2009 | American Standard Kitchen Faucet 6310 020...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Plumbing Logo
586 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
