Question about Jabra Bluetooth Headset with Voice-Dial Headset
Trying to get jabra vbt2050 to place voice command
Have new lg voyager. I Set up voice command on the phone but the bluetooth does not seem to trigger a call.
4 Suggested Answers
SOURCE: setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Posted on Jan 07, 2009
SOURCE: Jabra VBT2050 Bluetooth won't pair with LG Voyager
Something similar happened to mine. It worked for 2 months, and my phone received a message from jabra to reset pass key. It did not accept, and it stopped working with my phone. I tried everything. I was told to hold the power down for 10 seconds to place in pairing mode, that did not work. This did. Hold the volume up down and the answer button down at the same time for 7 seconds. You have to make sure they are all down or it will not work. You will see that the light will stay lit continuously. This means it is in pairing mode. Then place the bluetooth on your phone on. Tap find device at the top. It will then locate the jabra. Follow any other prompts. If it asks for a passkey, or code, 0000 will suffice. Hope this helps. I looked for almost an hour and a half for the answer.
Posted on Jan 31, 2009
  • 10 Answers
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Posted on Jun 06, 2010
Device can't understand voice commands.Keeps asking for commands and tries to call wrong contacts.
press and hold power and volume buttons to reset the device,pair it with the radio or phone and start over,when doing anything with voice you need to get rid of ALL background noises,including radio and air,(windows down),
Jun 13, 2015 | Motorola Mobility Motorokr T505 Bluetooth...
What is "time out" setting in voice prompts
When you try voice command and you cant speack any thing or sound is not clear than time out will appear If your voice is clear than your command are not found... Just try other word
Sep 11, 2012 | LG VOYAGER VX10000 Cellular Phone
How do I get my lg ally to respond to a voice dialer call command from my Jawbone bluetooth?
Hi bredebar you need to go to settings. Next you need to hit the wirless &network go to the bluetooth settings and make sure that the blue tooth is connect to the phone and audio. If your having a problem with the voice command it is because your ally doesn't have froyo on the ally. You need that to get the voice commands to work. you can go to the open market and put in voice commands for droids. Hope this helps foryo is frozen yogurt great name. There is another new program coming out be on the lookout for it .
Jan 03, 2011 | LG Ally Cell Phone
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
Voice activated dialing
Try going to Menu > Contacts > Voice Command
Apr 07, 2009 | LG RUMOR Cellular Phone
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Blue tooth voice commands
I had the same problem with a Motorola bluetooth. I had to return it to the store because it was defective. It wasn't a problem with the phone it was the bluetooth.
Jan 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Phone not ringing?
go to settings then phone settings then voice commands then call alert and put ring only
Nov 01, 2008 | LG VOYAGER VX10000 Cellular Phone
Jabra Bluetooth Headset with Voice-Dial Headset Logo
106 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
