Question about Kenmore 70172 Gas Commercial Dryer
Noiszzy dryer when running
Have a 70 Kmore series electric dyer.. an it started making a loud rubbing/grinding noise...I discovered that the white seal or spacer that is attached to the front of the tumbler has either come lose or broken could not tell for sure which this does not look an easy fix either... I am trying to get the part number for the seal/spacer and the repair instructions...thank you
  • Tolgo Mar 28, 2008
    I have a Kenmore 70 Series electric dryer. It has begun making a loud squeaking noise at times. What are some possible causes and can I fix it myself?
  • cstina Apr 13, 2008
    sounds like the same grinding metal on metal sound...everything else seems to work. afraid to keep using it beofre i know what is wrong and can i fix it by myself?
    Novelist:
    Champion:
  • 244 Answers
Could be your fan might be out of line slightly if so you can get some scissors and cut around your fan arms to stop it rubbing the seal at the front of your machine you can replace with self adhesive foam that you can put around windows and doors same kind of thing and you can get it from B@Q WHICKES and places like that not a hard job but you do have to pull drum away from it to do it also could be the bearings at the back if u grab ahold of your drum and see if it wobbles if it does most likely the bearibgs not a hard job just take screws out of back panel and youi will see your bearings m8
Posted on Aug 11, 2007
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My Bosch Dryer WTMC300us/01 is making a rubbing noise with or without items in the dyer. And it "smells" hot. What's wrong and can I fix it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 27, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Why is my dryer making a loud grinding noise
heatman101
sdfjkds
Nov 08, 2009 | Abbaka White Knight 44AW Electric Dryer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore Dryer electric 70 series will not start
The thermal fuse may be blown. The fuse is a white plastic item located behind the back cover on the blower box housing. It has two blue leads attached to it.
  1. Unplug the dryer.
  2. Remove the back cover.
  3. Identify the thermal fuse (white, two blue leads, one screw)
  4. Remove the two blue leads.
  5. Using a multimeter set to ohms, check the continuity of the fuse, it should "peg" the meter if the fuse is good, if the meter does not react, the fuse is blown.
  6. Remove and replace the fuse. Replacements can be found either online or at your nearest Sears.
Dec 31, 2007 | Kenmore 64952 Electric Dryer
Kenmore 70172 Gas Commercial Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
