Question about LG Computers & Internet
LG L1900E flickering after cold start
My one year old LG L1900E 19" LCD monitor, after 10 months of perfect working, started to flicker after a cold start.
It flickers all the screen as a stroboscopic light for a couple of minutes after I switch it on, or after coming out of sleep mode. I said "cold" start because this only happens when the monitor has been sleeping or switched off for a while (I didn't measure this "while").
After stop flickering, it works fine. If then I switch it off and on, there's no problem, because it is "warm".
It's not a video card nor drivers problem, because it flickers with my desktop and laptop. Neither an interface problem, because it flickers using the VGA and the DVI conectors.
Thanks
  • 1 more comment
  • Sebastian Salgado Dec 29, 2008
    I don't understand you fully. What do you mean with "rendering" and what is the setting I can adjust to correct the problem?
    Thanks
    My previous comment was an answer to mattattack13
  • XIVSander Jan 22, 2009
    Same problem with my LG L1970HR-BF, worked perfectly for about 1 year to 18 months and then sudenly started flickering for about 2-3 minutes ever time the monitor "cold starts".
    This is not a software issie because I have another samsung LCD to the left of the LG that is older but works without flickering allways.
    I noticed if I switch the setting on the monitor to shot more light it flickers less.
    I will probobly solve this issiu by throwing the LG piece of ... out and never buy an LG monitor again.
    Scholar:
  • 63 Answers
This is probably due to a bad solder joint somewhere. Bad solder joints can effect a unit in the reverse also. IE works at first and then dies after it gets warm. Think about how metal expands when it is heated. And contracts as it gets cold. If there is a hairline fracture on one or more component joints, this would cause it to not have such a great or solid connection when it is cool, or contracted. As it gets warmer, the solder expands therefore filling the void and giving it a good connection.
Regardless, it will likely only get worse over time. If you're handy with a soldering iron, pop it open and reflow all the joints. Especially the ones on the transformers and copper coils. Best to hit them all, excluding the tiny surface mount devices.
If you need further help or if you'd like to have this, or any other LCD monitor repaired for a flat rate fee of $40, please visit my web site http://BoiseLCD.webs.com, or email me at cjmclellen@msn.com.
BOISE LCD - LCD Monitor Repair
Chris McLellen
(208) 891-9117
cjmclellen@msn.com
Posted on Jan 03, 2009
I had this problem on a flat screen it is the rendering it useally will self adjust but you can set to a certian setting so it wont do it any more
Posted on Dec 29, 2008
  • mattattack13 Jan 02, 2009
    its in the graffics 3D rendering just google it and they will tell u where it is on your machine
Monitor flickers about 2 minutes after turn on. the flickering starts from the left and it eventually becomes a black screen. the monitor is 8 months new.
Unless I have the model number wrong (F1903), this monitor was relased in 2004. If it is 8 months old then it should be fixed under warranty. This can be bad problem in the bcaklight inverter circuits or bad lamps due to bad soldering works, bad power supply, please look here to see hwat is involved in repairing the monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 01, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
The backlight flickers when first started up, The flickering is pervasive, but only lasts about 10 minutes or so. I worry that the light is going out. Is this something that I could replace? I have...
I would check the capacitors on the power supply board first. This is the most common problem with LCD monitor after a year or two of service. Open the back and look for bulging capacitors, replace any that you find and you should be back going again. Check our web site at: www.ccl-la.com/capacitors.htm for pictures and information about this common problem. If you need to get parts or have over questions let us know at tech@ccl-la.com.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 15, 2010 | Acer AL1912 19" LCD Monitor
Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Jun 17, 2009 | Philips 190B6CB/27 19" LCD
Proview fv-926afw 19'' LCD flickers and buzzes
If you have a capacitor tester.. i'll be much better at least you would know which caps that actually failing..
I would replace all the caps if you dont have the tester.. and while your at it. try to resolder connections and some parts like transistor etc.. maybe they have "cold solder"
May 04, 2009 | Panasonic Computers & Internet
Hi, my monitor started to flicker 3times/second persistantly.
its the monitor its the main board may stuff up tomorrow may stuff up next week or in a years time hard to day as its only flickering take in for a check up
Apr 04, 2009 | LG FLATRON L1970HR LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
1,258 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
