Question about Sharp R-401CW Microwave Oven
Follow Up to Previous Power Concern
I posted a follow-up concern to a previous problem and wonder I should have just started a new post. I will just make reference to my follow-up questions on my "cooks fine, but..." post. Thanks!
  • Sharp Master
  • 9,150 Answers
Following up is okay. It's easier to follow.
Posted on Apr 27, 2007
Auto and general
The best thing you can do is contact your solicitor. It is unlikely you will find the help you need by posting under the microwaves section of the Fixya website.
Mar 26, 2014 | Microwave Ovens
Microwave beeps and with each beep a 6comes up on display, and the START under the numbers flashes, but I am unable to press any buttons to clear it. Also sometimes I can open the door and press the...
You didn't mention your brand or model number, so I can only give you a general response.
It sounds like a shorting membrane keypad.
On Samsung's, they will show the error code "SE".
For detailed do it yourself info and/or an estimate, please post a new FixYa help request and include the model, or contact me here with that info.
Jul 25, 2011 | Samsung MW6351G Microwave Oven
Control panel will not display anything
We would need the model number to help you.
Since FixYa is not notifying us Experts when folks follow up to posts, you'll have to post a new help request.
Apr 26, 2010 | Kenmore 80809 Microwave Oven
Control panel no longer displays on model 80802, 80803, 80804, 80809
Apr 26, 2010 | Kenmore Microwave Ovens
Our microwave all of sudden quit working. Had no
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1540 Microwave Oven
Lost power to microwave have power to outlet is it a fuse and where would that be
What i will tell you concern only certified technician. do that to your own risk .
Unplug the microwave oven, open the cover , then follow the cable from outlet, you will check that cable with meter , if that cable is good , you will see a fuse inside attached to one of the power cable. Check again this with ohmmeter. ...
Aug 30, 2009 | Microwave Ovens
'Start' button won't depress, seems jammed; timer knob broke off
the button is stuck because of food buildup over the years underneath the button, this happens even to newer ones after about a year of use, new microwaves are cheap and the lower end models start at only $35 from walmart I would reccomend buying a new one, newer microwaves use less power and are more effecient so a new one will pay for itself in saved electricty costs after about 2-3 years of use.
May 11, 2009 | Emerson Microwave Ovens
Arcing Microwave Oven
Look in cavity for any burn marks. If burn marks are present sand and paint area. You have to use paint made for microwaves. If no burn marks, Flash coming from magnetron and it would be time to replace. Yes it can be a safety concern, I would not use until fixed.
Mar 11, 2009 | Kenmore Microwave Ovens
No heat from my microwave maytag mmv1153aaw
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
But if when you start to microwave, if the turntable, inside light and internal light are not on, then you instead have a bad door switch or door switch mount, in which case you should see this:
http://www.microwavedisplay.com/doorsw.txt
Feb 13, 2009 | Maytag MMV1153A Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Sharp R-401CW Microwave Oven Logo
42 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
