Question about ViewSonic VA1930WM LCD Monitor
Viewsonic VA1930WM - Dead
This monitor fell off a desk and now it is dead as a doornail. Not even power.
Is there some kind of "shock" shutdown that am I not aware of? The thing only fell 3 ft and it was on thick carpet and I cant believe this could have killed it and I cant find my manual..... Thanks!
  • motrx Dec 29, 2008
    Would that prevent it from powering up? The power light does not even come on.
  • 741 Answers
Inside the monitor there are two backlight tubes about 8inches long and the thickness of a pencil. A fall could easily have broken the backlights. Probably should take it in for repair.
Posted on Dec 29, 2008
  • Randall  Trahan
    Randall Trahan Dec 29, 2008
    Well I really can't answer that because I do not know the extent of the damage. But any fall could have easily disconnected the small wires inside also. There is a very small wire that goes from the power button to the board inside the monitor that starts the whole process. If that wire came loose then yes it would not power up. The inside of monitors carry electricity even when turned off, I would only allow a certified repair shop to look at it. Keep in mind you can get a new 19" refurbished monitor from websites like TigerDirect for a little over $100, so don't spend to much on the repair.
More likely the power supply/inverter board may have failed due to bad DC caps which happen after about 2~3 years.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic and all others monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit:
Jul 31, 2010 | ViewSonic VA1930WM LCD Monitor
I have a viewsonic va1930wm. it turns off and on. how do i fix this
Is ur graphic card ok?
Have ur screen tested on another PC to determine exact cause...
Feb 06, 2010 | ViewSonic VA1930WM LCD Monitor
ViewSonic Main menu pop up all the time
Replace the button switch. That switch may worn out, Kindly give feedback after problem get solved
Aug 23, 2009 | ViewSonic VA1930WM LCD Monitor
Viewsonic VA1930WM
You need to isolate the problem to see if there's a problem with the monitor or with the sound card of the computer.
To isolate this problem, please try the steps below:
1. Make sure that the monitor is properly connected to the computer.
2. Check the volume of the monitor and the volume properties of the computer.
3. Try to connect your monitor into a known working computer.
Apr 15, 2009 | ViewSonic VA1930WM LCD Monitor
My ViewSonic va1930wm monitor has black spots.
How long have you owned it? Mine did the same thing. It was a dead spot which got worse. It was just past warranty (of course) but I took it back to Home Depot & they worked with me to get it replaced. Unfortunately, I think this is your only hope. The monitor dept. told me that once they get dead spots there is nothing you can do for them. Wish the news was better.
Feb 07, 2009 | ViewSonic VA1930WM LCD Monitor
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Viewsonic ve155b Dead
shine a flashlight into the monitor, if you can then see what is usually on your desktop, then your backlight has a problem.
Apr 17, 2007 | ViewSonic VE155b 15" LCD Monitor
ViewSonic VA1930WM LCD Monitor Logo
210 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
