LG WFT1071TP Top Load Washer
Problem for LG WFT1071TP Top Load Washer
LG +3 turbodrum wf t851 bE error code
By marctu on Dec 29, 2008
Hi, our washing machine shows bE code and stops working. I got it to work by applying some weight to the lid, but it stops between cycles. Now I've tried to restart it from the start of  a new load, but the code comes up straight away and nothing happens but the alarm. I think it may be a sensor problem or a balance issue. The motor and belt spin freely.
Cheers, Marc
Comments:
Jan 04, 2009
- I have referred back to the manual and it states that error bE indicates a "ball sensor" fault, no repairer I have spoken to knows what a ball sensor is. So I called the LG spare parts supplier and asked for a ball sensor and they had on in stock, it is inexpensive so I ordered it. Once it is installed I'll be able to determine if that fixes the problem, I'll keep you posted.
Jan 06, 2009
- FIXED!
Ok, the 'ball sensor' has arrived from the supplier. On the washing machine, it is located within the dash/control console casing. I took the two screws on either side of the back of the washing machine, lifted the casing from the back, unclipped it from the front and found the ball sensor on the left hand side of the machine. I unscrewed the ball sensor, unplugged it and replaced it with the new one. The ball sensor only cost $16 and hey presto... it's fixed! It was worth the punt considering the repairers I spoke had never even heard of a ball sensor. Thanks all.
Solution #1
posted on Jan 04, 2009
Somewhat Helpful)
billie927
Rank: Apprentice
Rating: 77%, 3 votes
I have the same problem. I do not think this has a micro switch to activate the wash cycle or spin. I have looked carefully.
I have a gut feeling that this works on a sensor similar to that of a sonic car alarm. It may have gone out of sync and needs to be retuned.
I have tried to find the software but it is not commercially available.
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Questions and Unsolved Problems for LG WFT1071TP Top Load Washer
Do you recommend LG WFT1071TP Top Load Washer?
Answer
Answer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes.... (More)
Answer
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and... (More)
Answer
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need... (More)
Answer
water accumulates inside drum and leakes out in my LG top loading machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG WFT1071TP Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
