Question about Arcade Golden Tee Unplugged Video Cabinet
Will not turn on, only a quick white flash and then blank screen
When I turn on my golden tee arcade game there is a quick white flash and then a blank screen. It does dot boot up. I used to be able to turn it off and on, and then it would start up. But now I can not get it to boot up. What could be causing this problem?
2 Suggested Answers
v4ndre
  • 148 Answers
SOURCE: I have a 2005 golden tee tournament edition, when
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Posted on Dec 07, 2010
Golden tee black screen
Are you able to advise some more detail for this issue please?
Can you play the game 'blind', which means coin it up, start a game and hear the game making normal gameplay sounds? If so this shows there is an issue with the monitor, or the wiring to the monitor.
Are there any lights lit up on the main game board inside the cabinet? If so this also shows there is an issue with the monitor, or the wiring to the monitor.
Is there any neck glow on the monitor tube, which is the back of the tube itself where it narrows down like a funnel to a narrow glass tube? If so this would indicate the monitor is most likely functioning and could be a game board issue.
You can also determine whether a monitor is functioning by turning up the brightness to full using the brightness potentiometer on the monitor chassis, or the potentiometer on the flyback transformer. The flyback transformer is the plastic looking device that the high tension lead comes out of and connects to the monitor tube, a lot like a spark plug lead connects from the cars distributor cap or coil pack to the spark plugs. It should show a lighter screen and probably with lines in it if the monitor is running.
Jan 24, 2014 | Arcade Golden Tee Unplugged Video Cabinet
Picture on golden tee is dark red not normal green did revert to green but back to red
Sounds like a cold solder joint. Unless you have knowledge of electronics and high voltage, I wouldn't try to fix it myself. A honest TV repairman should be able to fix it. And when I mean high voltage, I mean 2000-3000 volts is average with a CRT TV tube.
Dec 17, 2012 | Arcade Golden Tee Unplugged Video Cabinet
I have the 99 version and it was always on free play - something happened and now it charges and lost all of the data - how do I fix
Replace the CMOS/BIOS battery on the main board. Go into the settings and rechange all the settings to what you want them to be.
Dec 18, 2010 | Arcade Golden Tee Unplugged Video Cabinet
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
My golden tee freezes when i hit the ball in certain place and restarts
The first and easiest thing to check is the voltage supply to the game board. This should be 5 VDC, but may need to be 5.1 VDC as some games are a bit fussier.
Using a digital multimeter check the voltage from the switching power supply in the cabinet, which will be a medium sized metal box with multiple wires attached to it, and the two wires you need will be clearly marked '+5 VDC' and 'ground' or 'common' or 'negative'. If the voltage is incorrect there will be a small potentiometer or knob that can be turned to adjust the voltage. With the multimeter still connected adjust the voltage so the multimeter reads 5.1 VDC, or even better 5.2 as there will be a slight voltage drop between the power supply and the game board which will be approx 5.1 VDC by the time all the components on the board receive the power.
If you don't have a digital multimeter or are not too sure about the wiring at the power supply, you can go into the boot game into the test settings menu which will display the current voltage the board is receiving on the screen. You can then make the adjustments as necessary. Refer to the manual for details on how to boot into the test screen.
Hope this helps.
May 09, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Need manual for Hydro Thunder arcade
http://www.arcade-museum.com/game_detail.php?game_id=8161
hopefully that will help you with whatever your looking for
Mar 29, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Golden keeps rebooting
Vandre's suggestions are very good.
Some boards are fussy with voltage and need a small adjustment to find the setting they like best.
You can put the board into test mode/menu when you power it on, refer to the manual on how to do this, and see what the current voltage is being supplied to the board.
5.2 volts DC is a good setting for fussy boards. If it still reboots try 5.4volts, maybe 5.6 volts, but recommend going no higher than 5.6.
This will compensate for voltage drop across the board to getvit through the startup cycle.
Hope this helps.
Jan 24, 2010 | Arcade Golden Tee Unplugged Video Cabinet
When i turn the power on, the screen says detecting hard drive and then goes blank, no music or anything after that, but the golden tee complete sign above is still lit. thank you for your help
your harddrive is broken. the solution is buy a new harddrive. I hope you have a backup of your harddrive. if you haven't that you lost al your files.
it's hard srry but your harddrive is broken.
Aug 28, 2009 | Video Game Consoles & Games
Repair Service Arcade games
i have fixed arcade games since 1990. let me know what you need: (happycarnivore@yahoo.com)
Feb 25, 2009 | Arcade Golden Tee Unplugged Video Cabinet
Arcade Golden Tee Unplugged Video  Cabinet Logo
97 people viewed this question
Top Arcade Video Game Consoles & Games Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Michael Vincent Cruz
Are you an Arcade Video Game Console and Game Expert? Answer questions, earn points and help others
