Where is this o2sensor located
SOURCE: o2 sensor is comming up
Hi Steve ..it refers to the location of the oxygen (o2) sensors relative to the engine. The upstream sensor is the one closest to the engine. The downstream sensor is furthest from the engine. Think of it as the way a stream of water, or in this case, a stream of exhaust flows.... From the engine To the tailpipe.
Changing them is no problem, getting to them sometimes can be a bear,, if you can reach them,, its simply remove the old one with a couple of bolts, and unplug it,, and replace
