Question about Microwave Ovens
Microwave GE spacemaker 'jvm2070sh001', is not heating.
GE spacemaker in making humming sound and is not heating. There is also a slight burning odor.
  • 2 more comments
  • charese Dec 29, 2008
    Will this require expert repair help or can we fix this ourselves?
    Does this require expert home repair or can we fix this ourselves. Where is the magnatron(?) located?
    All the controls, vent, lights, and turntable works. Just no heat..
    I checked the ge recall list and this was not on it. Any other ideas?
    Guru:
  • 449 Answers
Here is a chart on how to test each component.but first
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
This is a common way to do this....
Posted on Dec 29, 2008
  • Jerry Parmanand Dec 29, 2008
  • 15,935 Answers
On a GE...with a louder than normal hum and not heating...most likely the mag, but could also be a shorted H.V. diode. Most of the time on those it's the mag, but you better have the diode replaced also even if it seems ok. Most GE's have 10yr warranty on the mag. If you don't know what you're doing leave servicing the high voltage circuit to the pros. Wouldn't want you to have a "shocking experience" or take the risk of exposing yourself/family to any radiation leaks.
  • blueextc3221
    blueextc3221 Dec 29, 2008
    The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
    Master:
  • 479 Answers
1. A wall-mounted microwave oven comprising:--------a body which is mounted on a wall and partitioned into a cooking cavity and a machine room;-------a magnetron which generates high-frequency electromagnetic waves and installed in the machine room;-------a control panel  which is detachably mounted on the body in front of the machine room, wherein the magnetron is mounted on a bottom surface of the machine room so as to be removable from the machine room without removing the body from the wall; and a plurality of fasteners which removable mount the magnetron and are accessible to be tightened or loosened from an outside of a lower end of the body so as to repair or replace the magnetron without removing the body from the wall.--------2. The microwave oven according to claim 1, further comprising a cover plate which is detachably attached to a lower end of the body and spaced apart from the bottom surface of the machine room.--------3. The microwave oven according to claim 2,
wherein the cover plate includes openings formed at corresponding positions of the fasteners so as to allow the fasteners to be tightened or loosened without removing the cover plate.
  • 151 Answers
Safety first. Unplug it and send to licensed technician. Depending on age maybe time for new one. If it's not working and something is burning it is not safe, and I am not comfortable offering ideas.
    Master:
  • 638 Answers
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
u can get the magnetron from- repairclinic websites.
    Scholar:
  • 68 Answers
DO NOT USE THE MICROWAVE!! It has probably been part of a recall. Contact the manufacturer located inside the door.
Good Luck, Phil
    Sergeant:
  • 359 Answers
More than likely a grounded out transformer for the low voltage control , usually about 80 .00 replacement in most models you must decide if worth fix
  • Microwave Ovens Master
  • 19,396 Answers
It looks like the magnetron is defective and is not heating.
The magnetron must be removed, tested , and replaced.
If the magnetron is OK, then it is usually a faulty control board, door sensor problems does not smell like burning.
  • 1 more comment
  • Ginko
    Ginko Dec 29, 2008
    All repairs on MW oven must be done by qualified technicians, as a badly repaired microwave is potentially dangerous for your health.
    Being more specific, if you have a loud buzz and no heating this can be caused by a defective power diode, high-voltage capacitor, or magnetron.
    If you have also burning smell from inside the owen, then it is usually the magnetron, that is located inside the owen, protected by a plate held with screws.
  • Ginko
    Ginko Dec 29, 2008
    Check here a general diagram, move the mouse on the diagram to locate parts:Counter topt
    Here instead there is a specific diagram for your model.
    The magnetron is PS953878,
    and part price is $126 .
    The diode is $50 : PS239843
    Capacitor is $46 PS239120
    all parts must be tested before replacement.
    A technician can do the job for $80, ask GE.
    GE Service and Support:
  • Ginko
    Ginko Dec 29, 2008
    Register Your Appliance with GE.
    Then call them Monday - Friday: 8 a.m. - 10 p.m. ET
    Saturday: 8 a.m. - 7 p.m. ET at .
    1-800-626-2005 for general enquiries.
    Or call GE Appliance Service
    1-800-848-7620 to get a quote for the repair.
    Call GE Warranty Management
    1-800-626-2224 to validate warranty, or ask price and availability for a warranty extension.
    Refer to my previous post for details on fault, part needed and part prices.
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
Dec 29, 2017 | GE Spacemaker JVM1540 Microwave Oven
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Jvm1790sk01 GE Microwave Broken - Manufactured Aug 2005. Working fine until tonight. Loud vibrating humming sound coming from Right Side and Burning Odor... No heating on high power. Just burning odor. ...
Sounds like you Magnetron has failed. The only way to repair this is to replace the part. Some microwaves have an extended warranty on this part. Check your manual and Call GE for service if it does. If the warranty has expired you might as well buy a new microwave unless you are very attached to this one. Hope this helps
Sep 01, 2011 | Microwave Ovens
GE profile spacesaver 2.0-does not heat and slight smell of electric burning when it is turned on. Turntable turns, fans work keypads work- just no heating and the electric odor. Filters and inside are...
MOST LIKELY YOU HAVE WHAT IS CALLED A MAGNETRON THAT HAS FAILED... IT IS THE PART THAT DOES ALL THE HEATING ...YOU DO ALSO HAVE A HIGH VOLTAGE TRANSFORMER THAT SEND POWER TO THE MAGNETRON BUT IT SOUNDS LIKE A MAGNETRON.... to be honest with you unless you are servicer it normally cost more to repair and for a few dollars more you can purchase a new one..... good luck to you.....
Jan 03, 2011 | GE Profile Spacemaker Over-the-Range...
Oven hums when turned on and doesn't heat, has burndt odor
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Oven humms and doesn't heat anymore....
if you say 'seems like common problem with this model' then just replace it and get another good model.
it gives peace in long run.
May 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
844 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
